Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    10
    summerfield, fl
    case 1835B
    Question $350 Hydraulic Shop Service on Drive Motor & Still Leaking
    Case 1835B Uniloader. Several months back I diagnosed a leaking wheel drive motor. Ordered & installed new seals from Coleman & reinstalled, still leaking. Removed & took to hydro shop- $900 estimate to repair. After hesitation the price dropped to $600. I said no thanks & reluctantly took it to another Hydro shop who's office looks like the county dump. This guy does great hose work for my brother so I gave him a try. He said the shaft needs machining, ok let's do it, should be less than $400. 3 weeks later & it's ready to pick-up. 2.5 hours to install & it's back in the machine. You guessed it, still leaks from the same place at the shaft filling up the chain reservoir. $350 later & the leaky motor is back in the machine. What would you do? Only consolation is I'm getting faster at removal but the big hose fittings are always a slow process.
  2. #2
    Join Date
    Aug 2004
    Posts
    1,440
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    Default Re: $350 Hydraulic Shop Service on Drive Motor & Still Leaking
    In my experience a problem shaft seal is usually due to a bad bearing.
    New motor price point:
    Case 1825,1835, and 1835B Drive Motor
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  3. #3
    Veteran Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,402
    Hooksett, NH
    Kubota B2320
    I'd be reluctant with the "shaft needs machining" statement......either the shaft is good or worn.......if it's worn then it needs a new one or a weld/machine (makeshift repair).....along with a new bearing too
    when they are welded and machined they lose hardness/strength
    It's very hard to compare prices when comparing different shops cuz some places will change more parts out or use OEM seal kits vs generic seals
    I'd say if it leaked right away then they did not bench test it after the repair....
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  4. #4
    Join Date
    Feb 2012
    Posts
    650
    Northern Michigan
    KIOTI DK50 HST
    Agree 100% on the bench test, but just food for thought does it have a case drain? Is it open to tank? CJ
    Kioti DK50HST Cab
    401 FEL
    Saws, 338xp,346xp mod,372xp mod, 390xp, Stihl combi 130 trimmer.
  5. #5
    Join Date
    Feb 2012
    Posts
    650
    Northern Michigan
    KIOTI DK50 HST
    Looking at brads info it looks like a TRW Ross. It also appears to have a case drain. A seal repair on similar motors $200.00 + hard parts like shaft, bearing ect. And that includes bench test. Check your case drain if hooked up. Also if the motor is beyond the service limit for the internals it will keep blowing seals. CJ
    Kioti DK50HST Cab
    401 FEL
  6. #6
    New Member
    Join Date
    Apr 2012
    Posts
    10
    summerfield, fl
    case 1835B
    Almost 3 weeks after posting this question & im still stumped. Do I end up shelling out the $1225 for a new wheel chain drive motor or what to get it going again? My brother suggest I only install a little pump to return the hydraulic fluid back up to the reservoir fill spout continually. Not sure what to do. Maybe $40 to ship my old one to L.P.S. for a benchtest?
  7. #7
    Join Date
    Mar 2004
    Posts
    143
    South Central Ky
    Kubota M7040HD
    If everything is not in tolerance they will leak. We don't warranty seal kits installed in motors. double any case drain.
  8. #8
    New Member
    Join Date
    Apr 2012
    Posts
    10
    summerfield, fl
    case 1835B
    What does-"double any case drain" mean?
  9. #9
    Join Date
    Apr 2010
    Posts
    2,402
    Hooksett, NH
    Kubota B2320
    Basically Compost you are between a rock and a hard place......If a new motor is avail it may be worth the extra to just buy it and be done with your troubles.....
    Just because some other guy said it was rebuilt, does not mean it was done properly or it just could be too far worn out.....hyd motors are not an easy part to rebuild if too much wear internally......most guys don't know what to look for even though they may be used to working on other hyd components
    Consider yourself lucky a new replacement is avail and suck it up.....
  10. #10
    Veteran Member chad22's Avatar
    Join Date
    Nov 2010
    Posts
    1,161
    Kansas Now Arkansas soon
    Home Built Excavator
    Quote Originally Posted by wdchyd View Post
    I agree. If you can lay out the cash for the replacement motor. Then I would just replace and be done with it. You might wind up throwing more money into the motor on repairs, than you would just buying a new one.
    Wish you luck.
    Chad
Similar Threads
  1. Replies: 12
    Last Post: 02-20-2012, 02:46 PM
  2. Converting a tractor shed into a metal shop
    By patrick_g in forum Projects
    Last Post: 10-29-2008, 07:11 AM
  3. Hydraulic remotes vs hydraulic PTO?
    By davesisk in forum Hydraulics
    Last Post: 10-23-2002, 08:35 PM
  4. Hydraulic drive for 3PT cement mixer
    By centex in forum Hydraulics
    Last Post: 07-14-2002, 09:30 AM
  5. PT hydraulic drive vs. CUT HST?
    By davesisk in forum Power Trac
    Last Post: 06-13-2002, 04:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
