Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Member
    Join Date
    Jul 2011
    Posts
    45
    Ashland, NE
    1965 International 504
    Default Re: Bucket not working correctly
    That is a very step by step for me to do it. It doesn't sound near as tough now. Will it be okay if I only do the bucket cylinders? The loader and rear blade seem to work well.
  2. #22
    J_J
    J_J is offline
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,491
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    You don't need to disconnect any hoses unless you want to actually see the flow into a bucket.
    For ordinary purging of air, just cycle the cyls to full extension and full retract. The air will exit the cyl into the return circuit.
    If you have cycle the cyl many times throughout this thread length, there should be no air in the system.
    The only thing that I can think of that would stop a cyl from fully extending or fully retracting, is if the return circuit is restricted, meaning there is no place for the fluid to go.
    Is the FEL relief going off while extending the curl cyl's, and if so, that means you are working at relief pressure. There is no logical reason for the cyl not to function, unless something downstream is blocking the flow, or a worn spot causing the cyl seals to leak near full retracted position..
    Is there a switch or lever you have to move to a certain position, maybe it is half way or something.
    If you continue to get air in the cyl, check for a suction leak on the pump.
    We haven't seen any pressure readings yet.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #23
    Member
    Join Date
    Jul 2011
    Posts
    45
    Ashland, NE
    The guy I bought the tractor from had put all new hoses on the Paulson loader.
    The loader had not been on the tractor for about 10 years he said. The two original bucket cylinders leaked bad and were not repairable so he bought two new ones from the Surplus Center in Lincoln, NE. I mounted them along with all the new hoses he had gotten. From that time on, the bucket has not worked well. I thought maybe a new transmission filter and new fluid would fix it. Not so and so now I am where I am. I have tried operating the loader and bucket many times to purge the air but it has continued not to fix it to work well. Because of that, I am ready to try purging them as you guys have stated.
    I also noticed the couplers on the tractor were using poppet style and the hose ends were ball so I changed the hoses to poppet also. That also did not help.
  4. #24
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,491
    JACKSONVILLE, FL
    Are the cyl an exact match for the old ones. Perhaps the stroke is longer that the others and the mechanical action will not let the cyl fully retract.
    Is the bucket hitting a mechanical stop?
    J.J.
    Git er done.
  5. #25
    Member
    Join Date
    Jul 2011
    Posts
    45
    Ashland, NE
    A hydraulic shop picked them out from the Surplus Centers website so I think they are very close. I don't know of any mechanical stops. They eventually close all the way but it is just very very slow to do it.
  6. #26
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,491
    JACKSONVILLE, FL
    You said the lift cyl work fine,
    Have you switched the hoses between the lift and the curl circuits just to see if there is any difference.
    When you curl up, does the relief activate?
    What pressure is on the cyl in the last 2 in of retract/curl up and fully retracted ?
    It should only take several hundred psi to curl an empty bucket, and when you hold the lever in full retract, the pressure should go to the FEL relief pressure.
    Install a 3000 psi hyd gage with a 1/4 in female QD in a tee in the IN port of the FEL valve. It will tell you the pressure in the hyd system for the implement circuit at any time the engine is running.
    Attached Thumbnails Attached Thumbnails Bucket not working correctly-hyd-gage-qd.jpg
    Attached Images Attached Images
    J.J.
    Git er done.
  7. #27
    Member
    Join Date
    Jul 2011
    Posts
    45
    Ashland, NE
    I thought about switching the hoses but they are not near long enough.
    How do I know if the relief activates?
    I haven't put a pressure gauge on yet (need to find someone with one).
  8. #28
    New Member
    Join Date
    Sep 2011
    Posts
    6
    John Deere 5525
    Default
    If all hoses were removed, check plumbing to assure it is correct. If a Line is crossed you can have limited operation. If a line is crossed you will also notice excessive hose flex while operating.
  9. #29
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,491
    JACKSONVILLE, FL
    Quote Originally Posted by retiredrich View Post
    When you max out the cyl, they will squeal or whine .
    Do you hear a particular noise when you hold the lever to long?
    J.J.
    Git er done.
  10. #30
    Member
    Join Date
    Jul 2011
    Posts
    45
    Ashland, NE
    JJ, I'll check for the noise/whine this week end when I bleed the air.
Similar Threads
  1. redoing old lane on the farm.
    By boggen in forum Projects
    Last Post: 06-06-2011, 11:17 PM
  2. Replies: 13
    Last Post: 05-03-2007, 10:24 AM
  3. Replies: 11
    Last Post: 03-26-2007, 10:22 PM
  4. hooks for my bucket
    By jmt1271 in forum Projects
    Last Post: 09-02-2006, 04:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
