boxer246
Member
I am trying to install an old Brantly FEL on my Kubota B6000, it was originally installed on a Iseki or something. I think the internal Hyd pump on the tractor is not up to the task for the FEL, so I wanted to try and install the external Hyd pump that was originally used for this loader. It was mounted on the front somehow, and driven directly off the front end of the crank.
Ideally I'd like to mount it the same way on the B6000, somehow adapting a shaft mounted to the front crank pulley, possibly through a Lovejoy coupler, connecting to the Hyd pump. My front crank pulley has three threaded holes in it....I was thinking of turning about a 3 1/2" steel disc on the lathe, bolting it to the crank pulley, then pressing in a 3/4" steel shaft slight interference fit with a woodruff key, (shaft would be like 7 or 8 inches long) then to the Lovejoy/ hyd pump.
Whatdya think?
Somehow, I need to get a 3/4" shaft attached to the front crank pulley, through the recess under the radiator, and sticking out front so I can attach the pump.
Whatdya think?
