Page 11 of 12 FirstFirst ... 89101112 LastLast
Results 101 to 110 of 114
  1. #101
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    grapple hydraulic setup 1026r-forumrunner_20121118_234348-png
  2. #102
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    grapple hydraulic setup 1026r-forumrunner_20121118_234509-png
    I built it out of scrap metal
    3/8 x 4 x 4" angle
    1/4 x 1.5 x 24" flat bar
    1/8 x 3 x 96" tubing
    1/4" mounting and lifting points
    1/4" chain to bucket
    All welded with 7018
    It can safely hold 800-1000 lbs at the lowest lug and 250 at the top lug
  3. #103
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    Thanks for sharing and again live that grapple.
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  4. #104
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Default Re: grapple hydraulic setup 1026r
    Quote Originally Posted by swick1 View Post
    What are you lifting there and what did it weigh from the looks of it it is very heavy.
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  5. #105
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    200 lbs of steel rigged at 9.5 ft from bucket pivot with the boom at a 45 degree angle. This is equivalent to 950 lbs at the pivot.
    At this height I could not lift, only curl.
  6. #106
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    Here's me as the counterweight. The rear end was very light
    grapple hydraulic setup 1026r-forumrunner_20121119_075807-png
  7. #107
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Ok from the picture it looked like a lot more weight.
    Montana R4944
  8. #108
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    Quote Originally Posted by Guesseral
    I know. I had a case 580 fill my pickup bed in two half scoops and my tractor took about 8 full buckets to unload it :-(
  9. #109
    New Member
    Join Date
    May 2013
    Posts
    4
    Oakdale
    JD 2320
    Swick1 I'm looking to adapt a power angle snow plow onto my 2320 with 200CX loader. This Solenoid looks like the way to go to get hydraulics diverted to the power angle cylinder. Is it a 2 way pressure valve? If so I could just divert the bucket curl/dump fluid when needed to change the angle of the blade. That would work great. Or any other advice you may have.
  10. #110
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    I had the Jd dealer cut the curl hose after I mounted the valve to the loader. They put new ends on it where they cut and hooked it up for me. I installed the two remote hoses myself. I made them out of repair fittings from discount hydraulics.com. they are frontier style disconnects but I would do flat face next time. Jd dealer had the covers for the hydraulic quick disconnects. I installed a foot pedal to switch between controlling bucket curl and the grapple. It works well but I had to make my own bracket to hold the switch. I love my diverter setup. I want to make some more implements that use the hydraulics like a stump puller and a shear / jaw crusher.
Similar Threads
  1. TC40DA grapple hydraulic ?s
    By boomer4snow in forum New Holland Owning/Operating
    Last Post: 08-03-2017, 02:15 AM
  2. Grapple Hydraulic control for Root Grapple
    By HarleyMonster in forum Attachments
    Last Post: 09-09-2009, 08:26 PM
  3. Hydraulic control for Grapple
    By HarleyMonster in forum Hydraulics
    Last Post: 09-09-2009, 08:18 PM
  4. Grapple Install
    By BamaRob in forum Attachments
    Last Post: 11-26-2007, 03:54 PM
  5. Hydraulic remotes vs hydraulic PTO?
    By davesisk in forum Hydraulics
    Last Post: 10-23-2002, 08:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
