Results 11 to 20 of 113
06-01-2012, 09:55 PM #11Platinum Member
- Join Date
- Jul 2007
- Posts
- 706
- Location
- WV
- Tractor
- John Deere 1026R
I found out tonight that tractor supply doesn't have nearly enough fittings to plumb this project. They didn't even have 3/8 qc dust covers! I'm just going to have custom hoses made at the hydraulic shop in town. I didn't like all of the fittings it was going to take or the stock hose lengths. May as well do it right. I don't want leaks or ugliness. Any idea the difference in price between hard lines and hose?
06-01-2012, 10:28 PM #12Platinum Member
- Join Date
- Jul 2007
- Posts
- 706
- Location
- WV
- Tractor
- John Deere 1026R
If the ground terminal of the valve is floating it should work. Surplus center datasheet may be wrong. It only shows two terminals hooked up.
Originally Posted by Zebrafive
06-01-2012, 11:45 PM #13
Re: grapple hydraulic setup 1026r
You should also add a diode at the Bosch valve, as close as possible to the valve connector. When the coil opens, it feedback voltage that can cause damage. I don't know the specifics of it, but it has been told to me a few times over the years by different people, so I'm pretty confident in the info. My wiring harness from Fasse had a diode soldered into it at the connector to the diverter valve, from the factory, FYI...
-Dave
"Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
Trailer - 10k/16' twin axle w/elec brakes
2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
06-02-2012, 06:19 AM #14Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,474
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Here is the reason for the diode.
When power is applied to the relay coil, a magnetic field is created and energy is stored in the coil. When power is removed, the magnetic field collapses causing a reverse voltage to be generated (it's called inductive kickback or back EMF). The back EMF can easily reach 200 volts. The diode will absorb the reverse voltage spike. This voltage, if not absorbed by the diode, will cause premature failure of switch contacts.
Flyback diode - Wikipedia, the free encyclopedia
Surge Suppression and Diodes Installation TipsJ.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
06-02-2012, 07:50 AM #15Platinum Member
- Join Date
- Jul 2007
- Posts
- 706
- Location
- WV
- Tractor
- John Deere 1026R
I agree with the diode suggestion. I will make it happen.
06-02-2012, 06:54 PM #16Platinum Member
- Join Date
- Jul 2007
- Posts
- 706
- Location
- WV
- Tractor
- John Deere 1026R
After 11 hours Cad work is done for the grapple bucket! I sent the nested parts drawing to the plasma cutter man. Next week may be bucket fab week!
06-04-2012, 09:10 AM #17Platinum Member
- Join Date
- Jul 2007
- Posts
- 706
- Location
- WV
- Tractor
- John Deere 1026R
Here are some pictures of my design. I added teeth between the two front tines so i could pick up firewood while facing it instead of being beside it.
06-04-2012, 09:24 AM #18Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,474
- Location
- JACKSONVILLE, FL
- Tractor
Will the added teeth affect your root rake ability?
J.J.
Git er done.
06-04-2012, 09:34 AM #19Platinum Member
- Join Date
- Jul 2007
- Posts
- 706
- Location
- WV
- Tractor
- John Deere 1026R
I'm not really sure how it will work. I assume it'll be like having a big ratchet rake on the front. I copied it from a toro dingo grapple I liked. I have a backhoe, so digging out roots isn't a huge priority for me. I mostly want to use this to clean up brush, trees, and construction debris.
06-04-2012, 10:49 AM #20Platinum Member
- Join Date
- Jul 2007
- Posts
- 706
- Location
- WV
- Tractor
- John Deere 1026R
I just got a call from the hydraulics shop after dropping off the tractor. They want $150/hr and think it will take 2-3 hours to make my hoses. I told them I didn't want the hoses installed yet, just made up and they wouldn't give me a price. I think that's a lot of money for what they are doing. I think i'm going to just buy stock hoses online, cut off one end of each hose, and use repair ends to plumb everything. Is this a bad idea?
Similar Threads
Grapple Hydraulic control for Root Grapple
By HarleyMonster in forum AttachmentsReplies: 4Last Post: 09-09-2009, 08:26 PM -
Hydraulic control for Grapple
By HarleyMonster in forum HydraulicsReplies: 2Last Post: 09-09-2009, 08:18 PM -
Grapple Install
By BamaRob in forum AttachmentsReplies: 62Last Post: 11-26-2007, 03:54 PM -
TC40DA grapple hydraulic ?s
By boomer4snow in forum New Holland Owning/OperatingReplies: 5Last Post: 06-29-2006, 07:40 AM -
Hydraulic remotes vs hydraulic PTO?
By davesisk in forum HydraulicsReplies: 6Last Post: 10-23-2002, 08:35 PM
