Page 3 of 12 FirstFirst 123456 ... LastLast
Results 21 to 30 of 113
  1. #21
    J_J
    J_J is online now
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,652
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: grapple hydraulic setup 1026r
    No, in fact it is a good idea, that way you can fix anything that goes wrong.
    That price per hour is excessive.
    Just get the fittings that match up to the hose.
    Try here.
    Field-Attachable (Reusable) Hose Fittings > Discount Hydraulic Hose.com
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    Quote Originally Posted by swick1 View Post
    I just got a call from the hydraulics shop after dropping off the tractor. They want $150/hr and think it will take 2-3 hours to make my hoses. I told them I didn't want the hoses installed yet, just made up and they wouldn't give me a price. I think that's a lot of money for what they are doing. I think i'm going to just buy stock hoses online, cut off one end of each hose, and use repair ends to plumb everything. Is this a bad idea?
    Just make your own from scratch: Re-Usable Hydraulic Hose Fitting Tutorial - TractorByNet.com
    That is a great project you have going on!
  4. #23
    Join Date
    Jul 2007
    Posts
    743
    WV
    John Deere 1026R
    Thanks guys, I have my order ready for discount hydraulic hose.com now! I'll post a parts drawing and list for future reference...
    25ft - R2-04 | 1/4" SAE 100R2AT Hydraulic Hose (by the foot)
    8 - R2-04-604 | 1/4" Hose x 1/4" JIC Female (Steel)
    2 - R2-04-504 | 1/4" Hose x 1/4" JIC Male (Steel)
    1 - PTFE Thread Sealing Compound, 1/4 pint
    10 - NPS-209 | 2.09" ID Nylon Protective Sleeve (by the foot)
    6 - R2-04-104 | 1/4" Hose x 1/4" NPTF Male (Steel)
    6 - 5405-06-04 | Extender/Enlarger, 3/8" NPTF Male x 1/4" NPTF Female (Steel)
    6 - 6801-04-08 | 90ー Elbow, 1/4" JIC x #8 SAE/ORB (Steel)
    2 - 5702-06-06 | 90ー Elbow, 3/8" NPTF Female x 3/8" NPTF Male Swivel (Steel)
    Attached Files Attached Files
  5. #24
    Veteran Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    1,944
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Solidworks user? Looks pretty good overall. Not sure about the way you did the front lower teeth, but if you have tried a similar design before and liked it, I can't argue with that.
    I'm not sure if you have a SSQA mount or something else, but if you have the SSQA, make sure the whole face plate of the tractor mount has some contact with the grapple structure, either by hitting against a tine, or adding some reinforcement.
    I also found adding expanded metal to the back of the grapple was a huge help in stopping sticks from poking my grill and hydraulic hoses and doesn't really hurt visibility. I used 3/4" x #9 flattened expanded.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
  6. #25
    Join Date
    Jul 2007
    Posts
    743
    WV
    John Deere 1026R
    Default
    I have Jd quick attach. I was planning on building the grapple first then deciding on how to attach it. I've built my own pallet fork carrier before so I know it's not too hard. I'll probably get some expanded steel from the scrap yard.
    The more I think about the front rake arrangement I become more unsatisfied with the design. I'll have to think about it more.
  7. #26
    Join Date
    Jul 2007
    Posts
    743
    WV
    John Deere 1026R
    I changed the lower teeth to provide more raking effect and added a saw profile to the back side for cutting roots. I tried a similar method on a backhoe root ripper that worked okay.
    Ripper thread: http://www.tractorbynet.com/forums/b...oe-ripper.html
    My plasma cut parts are going to be ready on Friday.
    My order total at discounthydraulichose.com was $267.86. It should be here next week.
    Attached Thumbnails Attached Thumbnails grapple hydraulic setup 1026r-grapple-2.gif   grapple hydraulic setup 1026r-grapple-22.gif   grapple hydraulic setup 1026r-grapple-21.gif
  8. #27
    Join Date
    Jul 2007
    Posts
    743
    WV
    John Deere 1026R
    Unwrapping my pallet felt like christmas morning! Plasma cost: $416 including material.
    Harbor Steel in Prichard, WV does great work. I was surprised they wrapped the pallet and deburred the parts for me.
    Attached Thumbnails Attached Thumbnails grapple hydraulic setup 1026r-2012-06-08-17.08.34.jpg   grapple hydraulic setup 1026r-2012-06-08-17.11.36.jpg
  9. #28
    Join Date
    Feb 2009
    Posts
    1,027
    CA
    2002 New Holland TC40S
    Price the custom made up hoses at your local NAPA store for a comparison. Use an air hose or the like as a surrogate to measure each hose as you progress toward the grapple and add a foot, have each set of hoses made up only on the upstream end, take them home, plug them in and finish measure, take them back for the downstream pressing along with the measurements for the next set and repeat.
    Having watched all four sets of my grapple hoses being built, each one didn't take more that 10 minutes per hose and I was charged flat fees for the fittings, hoses and pressings.
    You will need bulkhead brackets to turn the 90 degree corners at the FEL and a straight through at the docking/disconnect area, in my case a total of three. I built them out of 1/4" angle stock.
    I know it's a lot of time and work building the hoses this way but I only wanted to do this plumbing job once-that was over a year ago and so far no re-builds.
    Attached Thumbnails Attached Thumbnails grapple hydraulic setup 1026r-mie7.jpg   grapple hydraulic setup 1026r-mie10.jpg
    Let your tools do the work.
  10. #29
    Join Date
    Jul 2007
    Posts
    743
    WV
    John Deere 1026R
    Default
    Well I've already ordered the hoses and fittings but I appreciate the advice. I will need a couple of elbows to make it to the crossbar. I have considered stopping short though since my crossbar is much lower than yours and I don't want my qc's in the dirt.
  11. #30
    Join Date
    Apr 2010
    Posts
    1,944
    W Wisc
    Making hoses is a 5-min job for a hydraulic shop, unless something very weird is going on. Cut hose to length, Blow out saw debris, put fitting on end and place in crimper and hit it. 10-15 sec later the hydraulic crimper is done, and you repeat on the other end. I watched them make mine when I put together my 3rd function diverter valve. They are set up for it and it is easy for them.
    Whoever told you 2-3 hours was either trying to stick it to you or make you go away.
    -Dave
Similar Threads
  1. Grapple Hydraulic control for Root Grapple
    By HarleyMonster in forum Attachments
    Last Post: 09-09-2009, 08:26 PM
  2. Hydraulic control for Grapple
    By HarleyMonster in forum Hydraulics
    Last Post: 09-09-2009, 08:18 PM
  3. Grapple Install
    By BamaRob in forum Attachments
    Last Post: 11-26-2007, 03:54 PM
  4. TC40DA grapple hydraulic ?s
    By boomer4snow in forum New Holland Owning/Operating
    Last Post: 06-29-2006, 07:40 AM
  5. Hydraulic remotes vs hydraulic PTO?
    By davesisk in forum Hydraulics
    Last Post: 10-23-2002, 08:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
