Page 4 of 12 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 114
  1. #31
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    I got the bottom half of the grapple put together today. It's getting hard to man handle now :-)
    grapple hydraulic setup 1026r-forumrunner_20120616_234108-png
  2. #32
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    Too many buckets :-)
    grapple hydraulic setup 1026r-forumrunner_20120616_234450-png
    grapple hydraulic setup 1026r-forumrunner_20120616_234536-jpg
    grapple hydraulic setup 1026r-forumrunner_20120616_234610-png
  3. #33
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default Re: grapple hydraulic setup 1026r
    I made some more progress this morning. The plasma cutter made the holes about 0.050" undersize, so i had to drill them out, but they were hardened by the nitride layer that the plasma cutter makes and it was a pain in the butt. I started working on the top half and i'm getting ready to tack the hinges on this evening. It's just too hot to work in the daytime when I don't have any shade with our temperatures of 94 degrees and 70% humidity.
    grapple hydraulic setup 1026r-2012-06-20-09-05-a
    grapple hydraulic setup 1026r-2012-06-20-09-21-a
  4. #34
    Join Date
    Oct 2011
    Posts
    1,963
    Monrovia, California
    Kubota BX25
    I do not know how powerful your tractor is, but if shes a brute
    I would be addin' some gussets swickster. Instead of a hole your
    favorite superhero logo / whatnot is fun...
    I bought my own hose maker. I am SO GLAD I did instead of being
    at the mercy of the kid at NAPA I was able to make them my way
    at my speed. I hooked up one end and hand fit it, then routed
    the hose to the other end and measured.
    Kinda comes out perfect that way.
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  5. #35
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    Thanks artisan. I'm going to put some gussets on the horizontal tines like you suggest. The quick attach plates should stiffen the vertical tines.
  6. #36
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,842
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    I don't think those gussets are really needed if you are already using 3/8" steel. Nobody seems to have lateral stability issues within the grapple itself. Now if you are considering more gusseting, I would suggest the joint at the bottom rear where the uprights and the horizontal tines join at the square tube. Deeper gussets there may be wise as that could affect the strength during digging/prying operations.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  7. #37
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    More progress today. The cylinder is interfering with the grapple when it is fully open because i drew a welded cylinder in my modeling software, but decided to buy a tierod cylinder. I guess it didn't save me $10 after all I will fabricate a new bracket for the rod end because my range of motion is still about an inch less than what I would like.
    I decided to use bolts and washers from Tractor Supply because that's what the dingo grapple uses. I am going to get some longer bolts so only the smooth part under the head is taking the shear loads. I also put washers between the hinged parts so i could accommodate warping from the welding process. I figure it's easier to grind down a washer surface to get a nice fit than it is to grind my grapple.
    grapple hydraulic setup 1026r-2012-06-20-21-29-a
    grapple hydraulic setup 1026r-2012-06-21-07-12-a
    grapple hydraulic setup 1026r-2012-06-21-10-17-a
    grapple hydraulic setup 1026r-2012-06-21-10-18-a
  8. #38
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    I cut out a new bracket. Now everything fits! I am almost finished welding now! I decided to use grade 8 bolts as pins and cut down the threads so only the smooth unthreaded parts are actually rolling in the hinge.
  9. #39
    Gold Member gumshu's Avatar
    Join Date
    Jun 2009
    Posts
    469
    Atascadero, Ca. & Selma, Or.
    Kubota M7040, Bobcat CT235, Kubota BX23 TLB & RTV 900
    Nice job! I wish I knew something about welding.
    F350 6.4 Dually, PJ 14K 20', PJ 3.5K
  10. #40
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    gumshu: Just pick up an angle grinder and an old AC stick welder from craigslist and you can be welding for about $300. I didn't know anything about stick welding until last fall when I started messing around with building attachments. So far I've built a ripper, boom pole, plow, trailer mover, and pallet forks. I think I've burned through about 10lbs of rod. I'm just now learning vertical up. I think edge prep is more important than technique, but of course, both are important.
    This video will get you started: http://www.youtube.com/watch?v=zWdgE...eature=related
    Here are the pictures from last night. I couldn't get them to upload yesterday.
    grapple hydraulic setup 1026r-2012-06-25-19-34-a old (top) and new (bottom) brackets
    grapple hydraulic setup 1026r-2012-06-25-21-20-a
    grapple hydraulic setup 1026r-2012-06-25-21-21-a
Similar Threads
  1. TC40DA grapple hydraulic ?s
    By boomer4snow in forum New Holland Owning/Operating
    Last Post: 08-03-2017, 02:15 AM
  2. Grapple Hydraulic control for Root Grapple
    By HarleyMonster in forum Attachments
    Last Post: 09-09-2009, 08:26 PM
  3. Hydraulic control for Grapple
    By HarleyMonster in forum Hydraulics
    Last Post: 09-09-2009, 08:18 PM
  4. Grapple Install
    By BamaRob in forum Attachments
    Last Post: 11-26-2007, 03:54 PM
  5. Hydraulic remotes vs hydraulic PTO?
    By davesisk in forum Hydraulics
    Last Post: 10-23-2002, 08:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
