Results 71 to 80 of 113
07-19-2012, 07:41 PM #71
Re: grapple hydraulic setup 1026r
Dennis
CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
07-19-2012 07:41 PM # ADS
08-12-2012, 10:02 PM #72
08-12-2012, 11:54 PM #73Veteran Member
- Join Date
- Oct 2011
- Posts
- 1,829
- Location
- Monrovia, California
- Tractor
- Kubota BX25
Looks store bought! Congrats!
Regards,
Artisan
Kubota 2012 BX25 (23H.P. / 17.7pto)
14' Dump / Carson 12K Tow Trailer w/ movable Winch,
Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
Stayin' Alive (This click could save a life...)
08-13-2012, 09:07 PM #74Platinum Member
- Join Date
- Jul 2007
- Posts
- 744
- Location
- WV
- Tractor
- John Deere 1026R
Thanks. I'm heading to deere tomorrow to get the fittings I don't have. I decided to split the original loader lines and terminate the ends at the valve
08-18-2012, 10:36 PM #75Platinum Member
- Join Date
- Jul 2007
- Posts
- 744
- Location
- WV
- Tractor
- John Deere 1026R
The tractor is back and the tractor side hydraulic hoses are connected. I'm going to plumb the grapple cylinder to the quick connects for my new front work ports and hook up the electric switch tomorrow. Wish me luck! I'll take pics when it works and post an updated parts list.
08-20-2012, 10:56 PM #76Silver Member
- Join Date
- May 2012
- Posts
- 119
- Location
- Lake City, Michigan
- Tractor
- CaseIH 685 & JD 3320
Hello;
I'm kinda in the same boat as Swick1. A couple weeks ago a Wildkat 48" Econo Grapple was delivered to me. So now i'm in the getting hoses, couplers and routing stages.
Regarding hoses. I found that our local JD dealer was the cheapest per foot cost on the hoses. How much to attach ends I don't know. NAPA was considerbly more per foot
Thanks,, nicholas
10-04-2012, 11:38 PM #77Platinum Member
- Join Date
- Jul 2007
- Posts
- 744
- Location
- WV
- Tractor
- John Deere 1026R
I got the valve and hoses done. I used a footswitch to activate the valve and hooked into a spare switched connection provided by Jd for a lift solenoid kit that hasn't materialized. The switch is after the valve and connects to the ground connection on the engine.
10-05-2012, 08:56 PM #78Platinum Member
- Join Date
- Jul 2007
- Posts
- 744
- Location
- WV
- Tractor
- John Deere 1026R
Ok, the valve clicks but doesn't allow the fluid to escape the grapple ports even when I crack the fittings. Any ideas? I've already tried reversing the polarity. The valve is getting pressure.
10-05-2012, 10:45 PM #79Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,656
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
You may have the solenoid on to tight.
Also don't over tighten the mounting bolts.
Some solenoid valves have a manual mode of operation.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
10-06-2012, 07:51 AM #80New Member
- Join Date
- Oct 2012
- Posts
- 7
- Location
- Bainbridge
- Tractor
- 5010 mahandria
Similar Threads
Grapple Hydraulic control for Root Grapple
By HarleyMonster in forum AttachmentsReplies: 4Last Post: 09-09-2009, 08:26 PM -
Hydraulic control for Grapple
By HarleyMonster in forum HydraulicsReplies: 2Last Post: 09-09-2009, 08:18 PM -
Grapple Install
By BamaRob in forum AttachmentsReplies: 62Last Post: 11-26-2007, 03:54 PM -
TC40DA grapple hydraulic ?s
By boomer4snow in forum New Holland Owning/OperatingReplies: 5Last Post: 06-29-2006, 07:40 AM -
Hydraulic remotes vs hydraulic PTO?
By davesisk in forum HydraulicsReplies: 6Last Post: 10-23-2002, 08:35 PM
