Results 1 to 6 of 6
06-11-2012, 12:27 PM #1New Member
- Join Date
- Jun 2012
- Posts
- 3
- Location
- Amherst, WI
- Tractor
- Case 380B
Adding remotes to a Case 380B
Hello,
I have a 1988 Case 380B and want to add a loader and hydraulic remotes to it. This is Case's utility version of the 495. I have attached a picture of my setup and I am hoping someone can give me some advice. I am also looking for the auxiliary valve and remote set up.
I realize that the loader could run off of the remotes but I would like to "hard" plumb it into the tractor. Do I have a "power beyond" block on top of the trans? One of the lines coming out of it feeds the draft control valve.
Where the large hose threads into the side of the tranny is where the book shows the remote valve bolting onto. The hose is running back to the multicontrol valve. Is there pressure on this hose and they have the pressure just dumping back into the return? Once I bolt the remote valve on, would this hose then become the return for the remotes? Any help would be appreciated. Thanks, Eric
06-11-2012, 12:31 PM #2New Member
- Join Date
- Jun 2012
- Posts
- 3
- Location
- Amherst, WI
- Tractor
- Case 380B
Re: Adding remotes to a Case 380B
A couple more pictures.
06-11-2012, 02:10 PM #3
Looks like it's the same basic tractor as the Ag 885 too. You should be able to find parts to add remotes at a salvage yard.
Mark1720 Ford 4x4 w/ 7108 FEL
Case 1845 Uni-Loader NO it's NOT a "C"
190C John Deere
Various implements, some store bought, some home made.
09-28-2012, 02:50 PM #4New Member
- Join Date
- Jun 2012
- Posts
- 3
- Location
- Amherst, WI
- Tractor
- Case 380B
Anyone else?
01-22-2013, 10:37 PM #5New Member
- Join Date
- Jan 2013
- Posts
- 1
- Location
- big rock
- Tractor
- case 380b
01-23-2013, 07:43 AM #6Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,467
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
What is the function of the valve in the pic.
If you can determine if the hyd system is an open center hyd system, then you can add a loader valve with PB is series with the other valves.
If it is a closed center, you can add a loader valve in parrallel with the other valves.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
Similar Threads
Adding Kubota rear remotes
By adamshatch in forum Kubota Owning/OperatingReplies: 11Last Post: 08-03-2012, 09:02 AM -
Adding rear remotes to kubota l35
By FF110 in forum HydraulicsReplies: 29Last Post: 12-14-2011, 07:06 AM -
Selector valve for adding remotes
By jas67 in forum HydraulicsReplies: 4Last Post: 03-19-2009, 10:21 AM -
adding rear remotes to my tractor
By andrewj in forum CustomizationReplies: 4Last Post: 02-06-2006, 01:27 AM -
Adding more remotes
By Rowski in forum Kubota Owning/OperatingReplies: 9Last Post: 05-13-2001, 09:40 AM
