Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    7
    Devon, England
    Case 885XL, Case CX100
    Default 1989 Case 885 XL standard transmission 4WD Hydraulic Oil Level...
    Hellow Chaps, If I check the level cold, its about 2.5" over the Max line on the dip stick, If I check it hot, just after switching off it is about 2" over the Max line.
    Is it really over-full? What can be damaged by having it too full?
    Any help appreciated, everything else on the old girl is fine :-)
    Adam
  2. #2
    Join Date
    Jul 2011
    Posts
    59
    IH 684
    Default
    On my 885xl 2wd you check the hydraulic oil after idling for a couple minutes at 1400 RPM. I imagine the MFWD is the same but I would have to look. I image you are ok running it a little over full.
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    7
    Devon, England
    Default Re: 1989 Case 885 XL standard transmission 4WD Hydraulic Oil Level...
    Thank you Husker, I agree, it's just too full, is it worth draining, or will it not matter??
  4. #4
    Join Date
    Jul 2011
    Posts
    59
    IH 684
    Default
    It is different than having your engine too full. I would not worry about it as long as it is not so full it is running out of places it shouldn't be. You are checking it with it running, right?
  5. #5
    New Member
    Join Date
    May 2012
    Posts
    7
    Devon, England
    I'm an idiot Husker, I have been turning off and then checking it, thank you, I will re-check in the morning, with the engine on this time, I will report back :-)
  6. #6
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    The system should be checked warm or operating temp.
    If using no external hyd cyl for anything, the level should be on the mark.
    If using an SA cyl, you may need extra volume for the additional cyl. Collapsed cyl has no fluid in it.
    A DA cyl may have fluid on one side of the piston.
    A 2 in bore cyl,with a 20 instroke may contain .27 gal of fluid.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  7. #7
    New Member
    Join Date
    May 2012
    Posts
    7
    Devon, England
    Thank You J_J, of course, I didn't consider the cylinders, I checked it this morning, running, just a mess of oil right up the stick, so I filled both cylinders switched off, level was about an inch above max, but with cylinders empty it went up another inch and a bit, so I think all I need to do is make sure it never goes below the max and not worry about it
    I hear you had a bit of rain last week! My boss lives in Stuart, but says the aquifer is still low?
    Kindest Regards
    Adam
Similar Threads
  1. Replies: 0
    Last Post: 03-09-2011, 06:53 PM
  2. 3-Point Hitch Hydraulic Oil in a Case/DB 885
    By jriggs10 in forum Case-IH
    Last Post: 05-14-2010, 09:19 AM
  3. Oil & Fuel GC2300/GC2310 transmission/hydraulic oil level
    By FredWalter in forum Massey Ferguson Owning/Operating
    Last Post: 07-30-2008, 09:08 PM
  4. Oil level 4WD
    By tech22 in forum Yanmar
    Last Post: 05-15-2006, 11:58 AM
  5. Transmission oil Level, how much is to much???
    By Jer in forum Owning/Operating
    Last Post: 12-13-2003, 07:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
