Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,091
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default How do I get rid of the flop in a cx200 fel???
    My JD cx 200 fel flops on the curl function. It use to be only a little (maybe an inch or so) but now its getting worse(2-4inch of play). The dealer thought it was air caught in the lines and he told me it would work itself out. Well it hasn't and its getting a little worse. Its more of an annoyance then a problem but how can I fix it? Is it air or foaming?
    The tractor has 200 hrs on it and the fluid has never been change I don't think.
    Can I just brake the lines and bleed them or is there more to it?
    The loader (almost) never comes off.
    Also is there an adjustment I can make on the loader? The loader on my 2320 works smoothly but the one my 2305 is touchy when I try and do fine work. It's almost like the flow rate is to high.
    Thanks alot for the help ahead of time. I've never really played much with hydraulics....yet!
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  2. #2
    J_J
    J_J is offline
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,491
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: How do I get rid of the flop in a cx200 fel???
    Are you using the regen mode all the time?
    Try holding the lever full down until the relief goes off.
    Try using the power mode for slower dump. Should have constant pressure.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Silver Member heviduty's Avatar
    Join Date
    Apr 2012
    Posts
    155
    central NC
    Kubota L3400HST/LA463 loader JD 318 / 3ph(cat. 0)
    Worn pins?
    Happy as if I had good sense.
    One orange, one green.
  4. #4
    Super Star Member RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    15,683
    Bethel, Vermont
    John Deere 4400 MFWD
    Try something easy first...disconnect your loader lines (The 4 quick disconnects) and reseat them...see if the helps. You may have one pulling a little air, so make sure they're clean. Use a screwdriver or pin to push the check balls on the female fittings (a little hydraulic fluid may spurt...use a rag over the fitting) and just press the male fittings against a block of hardwood or even a cement floor (if you're careful). Use a rag over the male fitting when you do this and expect a spurt of fluid.
    Roy Jackson
    A fear of weapons is a sign of retarded sexual and emotional maturity...
  5. #5
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    1,290
    W. Central Louisiana
    JD 5085M; NH TN70A; Ford 2600
    Quote Originally Posted by heviduty View Post
    Worn pins?
    Not likely. Only 200 hours on the machine.
    As J_J or Roy suggested, probably air in the system.
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    JD 457 round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '95 Kenworth.
    Don’t ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
  6. #6
    Join Date
    Nov 2011
    Posts
    1,091
    Quote Originally Posted by J_J View Post
    What is the regen? If that is the float function then I barely use it, mostly in the winter snow(oppose to he summer snow I guess).
  7. #7
    Veteran Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,402
    Hooksett, NH
    Kubota B2320
    Hopefully it's not one of the nuts on the end of the piston rods in the bucket curl cyls coming loose.....is the 2-4 inches of play measured at the bucket or at the cyl rods
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  8. #8
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,491
    JACKSONVILLE, FL
    Regen is where the rod end fluid is mixed with the pump fluid to fill the base end of the cyl faster. The bucket will dump faster but with less power.
    Some valves have regen in the first part of lever movement and other valves have regen in the far right position.
    If you put a hyd gage in the system, you can see the pressures generated.
    J.J.
    Git er done.
  9. #9
    Join Date
    Nov 2011
    Posts
    1,091
    Default
    There's no pressure gage on the 2320. I don't think it has Regen, but I'm only guessing.
  10. #10
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,491
    JACKSONVILLE, FL
    Tractors don't usually come with hyd pressure gages.
    You add them for maintenance and trouble shooting.
    Attached Thumbnails Attached Thumbnails How do I get rid of the flop in a cx200 fel???-hyd-gage-qd.jpg
    Attached Images Attached Images
    J.J.
    Git er done.
Similar Threads
  1. Loader cx200 loader
    By x everything in forum John Deere Owning/Operating
    Last Post: 12-06-2011, 03:34 PM
  2. Tires 2320 Front Tires Rubbing CX200 FEL Stand Bar
    By bill1369 in forum John Deere Owning/Operating
    Last Post: 12-05-2008, 10:19 PM
  3. How do people like the JD forks for the cx200?
    By tomd999 in forum John Deere Buying/Pricing
    Last Post: 08-14-2007, 07:28 AM
  4. 2305 and a CX200
    By stuarth in forum John Deere Owning/Operating
    Last Post: 11-12-2006, 11:09 PM
  5. L35 Loader Bucket Flop
    By cheekme in forum Kubota Owning/Operating
    Last Post: 10-22-2003, 09:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
