Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Aug 2012
    Posts
    8
    atlanta in
    1958 MF 65
    Default MF65 hydralics
    I have seen a few post on here about this but I am having a little trouble understanding what I am wanting to do with this. 1958 MF65. it has a front loader that works off of a unit hooked up to the rear PTO spline. The loader has a hydraulic control valve on it that I use to move the bucket and arms. I would like to be able to use the rear PTO for other things and not have to unhook the loader. I am going to post pictures with this. Can I move the supply line from the rear unit to the thing under my seat. and if so which hole do i hook it upto. what about the big return line. can I just cap it. the control unit on the loader has a return line also.
    Attached Thumbnails Attached Thumbnails MF65 hydralics-mf65-hydralics-1-jpg   MF65 hydralics-mf65-hydralics-2-jpg   MF65 hydralics-mf65-hydralics-3-jpg
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: MF65 hydralics
    You have more than sufficient hyd on your tractor, just run a hose from the tractor pump to the IN port of your FEL valve and connect the PB or OUT hose to the input to the 3pt.
    Hydraulics:
    Capacity: 8 gal [30.3 L]
    Pressure: 2500 psi [172.4 bar]
    Pump flow: 4.76 gpm [18.0 lpm]
    TractorData.com Massey Ferguson 65 tractor information
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    New Member
    Join Date
    Aug 2012
    Posts
    8
    atlanta in
    1958 MF 65
    Quote Originally Posted by J_J View Post
    Hydraulics:
    OK is the FEL valve the one on the loader? the tractor pump the one under the seat, and if so which hole do I hook to there are many? I just replaced the brake pads and had to change the hydraulic fluid 8 gallons. but the loader also carries its own fluid in the frame of the loader.
    when you say hook the out hose to the input of the 3pt I am not sure on that I am trying to get rid of the 3pt hook up pump.
  4. #4
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    I am not sure what all you have there. but the tractor came with a hyd pump and a 3pt system.
    Is that equipment still there.
    Maybe the previous owner got the loader and pump as a pkg, and install it that way.
    If you still have the hyd pump and it is still good and running normally, then the pump is supplying hyd fluid to the 3pt as regular tractor operation.
    Let us know if your tractor hyd pump is working.
    According to Tractor Data, you have enough GPM and 2500 psi to run a loader.
    J.J.
    Git er done.
  5. #5
    New Member
    Join Date
    Aug 2012
    Posts
    8
    atlanta in
    1958 MF 65
    all 3 things in pictures work. I guess my problem is the names of everything. I am guessing the thing under my seat is the 3pt pump. is there a spot on it to hook a supply line to and then run that line to the controller on the front loader.
  6. #6
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    I don't know the specifics on your tractor, but in general, you would run a hose from the hyd pump OUT port to the FEL valve IN port, and then run a hose from the PB to the 3pt port. The OUT port will go to tank.
    If your hyd plumbing is internal, then you will have to look in your manual and find the correct ports.
    Your hyd tank/reservoir is about 8 gal, so you do not need the reservoir in the loader arm.
    After changing the FEL system to use tractor hyd, and after cycling all the cyl, then replenish the hyd fluid in the reservoir.
    If that loader valve does not have PB, and you want to keep it installed, then you would use the OUT port on the loader valve to feed the 3pt. Not recommend, but it is what it is.
    You can get a new joystick loader valve for about $248, with float and regen.
    Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
    J.J.
    Git er done.
  7. #7
    New Member
    Join Date
    Aug 2012
    Posts
    8
    atlanta in
    1958 MF 65
    Ok been a little busy and still do not have this completed. In the first picture that is the hydralic pump for the 3pt. it works. my question is where on the pump under my seat can I hook up lines to the 2nd picture which is the control valve for the loader. that would enable me to get rid of third picture which is a pump mounted to the pto shaft.
    I have a service manual but it only tells me how to rebuild the 3pt pump not where i can hook up to it. I think this should be as easy as unhooking the supply and return line from the PTO pump. and connecting them to the pump under my seat.
  8. #8
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    I do not see a hyd pump in the above first picture, however it could be internal, you tell me.
    Do you have an external hyd pump other than the PTO pump?
    Show a picture of the pump output if available.
    Do you have a parts manual, or owners manual?
    This might be what your pump looks like.
    Attached Thumbnails Attached Thumbnails MF65 hydralics-14e9_1-jpg   MF65 hydralics-massey50oppdf-jpg
    J.J.
    Git er done.
  9. #9
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,883
    Hooksett, NH
    Kubota B2320
    the pto pump under your seat is a Gresen TB-** vane pump, (the next numbers are the gpm's at 1200 (?) rpms)
    http://www.maxxhyd.com/PumpsGresen.pdf
    Check out page 177
    Pump Tc-24 Gresen 24 Gal @1200Rpm Counterclockwise
    is another view at a marine outlet, they use these for different purposes
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  10. #10
    New Member
    Join Date
    Aug 2012
    Posts
    8
    atlanta in
    1958 MF 65
    Quote Originally Posted by wdchyd View Post
    Check out page 177
    so is that underneath the panel under the seat? when I look at that panel I see a lot of people hook up control valves on the right hand side. I do not need a control valve and I will have to use the fluid in the arms of the loader or change the lines all together as the bucket tilt lines just hook into the arms and do not come from the control valve.
Similar Threads
  1. I need help with my MF65 hydraulics!!
    By dmaxwayne in forum Massey Ferguson Owning/Operating
    Last Post: 01-25-2011, 06:11 PM
  2. MF65 IP removal
    By dkarten in forum Parts/Repairs
    Last Post: 09-13-2009, 01:16 PM
  3. MF65 will not start
    By AGRI-FIX in forum Massey Ferguson Owning/Operating
    Last Post: 06-15-2009, 02:05 AM
  4. Oil & Fuel mf65 diesel
    By rockyclift in forum Massey Ferguson Owning/Operating
    Last Post: 06-15-2009, 01:55 AM
  5. MF65 Governor adjustment?
    By KennyV in forum Massey Ferguson Owning/Operating
    Last Post: 09-16-2006, 09:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
