Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Oct 2012
    Posts
    4
    Gallatin
    Ford 5200
    Default solenoid valve with power beyond capabilities
    hello, new to the forum here. I am wanting to add a solenoid controlled valve for a FEL grapple to an existing power beyond circuit, however I can't seem to find one. Do they exist? I have a Ford 5200 (5000 row crop platform tractor) in which I added an adaptor plate which basically runs a power beyond to the loader joystick, from there a pb to a single spool valve (to add another set of hydraulic remotes) and pb back to run the 3 point hitch. my hopes were that I could find a solenoid controlled valve that has power beyond capabilities, run it in the circuit, and I could rig up a switch on my joystick. I'm sure i'm not the only person in the world who has attempted this before. it seems simple to me, a simple single spool valve (w/ pb of course) that has an electronic solenoid in place of where a lever would be? any help in this dilema would be greatly appreciated.
    I know I could just run hoses back to my one of my remotes, but I would like to keep my remotes free for implements.
  2. #2
    Gold Member jcliburn's Avatar
    Join Date
    Apr 2009
    Posts
    278
    Lawrence County, Mississippi
    Kubota MX5100
    Default Re: solenoid valve with power beyond capabilities
    Google "site:tractorbynet.com 3rd function" and you should be off and running.
  3. #3
    J_J
    J_J is online now
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,482
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Solenoid manifolds are already designed for high pressure, and therefore don't need a special port.
    You can put a solenoid assembly anywhere in the series path of an open center circuit.
    Surplus Hydraulics has lots of solenoid valves you can use.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Join Date
    Nov 2006
    Posts
    189
    This is a 12v solenoid control valve off of a JD planter. Its used to control the marker boom. Most seeder planters have them and can be found in salvage lots.
    Surplus Center has solenoid control valves, also try Ebay they have many listed.
    Attached Thumbnails Attached Thumbnails solenoid valve with power beyond capabilities-dscn8380.jpg
  5. #5
    Join Date
    Jan 2010
    Posts
    1,875
    Northern, IL
    Branson 2400H
    Quote Originally Posted by J_J View Post
    You can put a soleoid assembly anywhere in the series path of an open center circuit.
    This depends on the type of solenoid valve being used. Some D03, D05 style manifold/subplate mount valves will not allow more than 1000,1500 PSI in the tank line others will allow 3000 + PSI. When used in series this type of valve must be able to have the "T"-Tank line pressurized.
    Screw-in cartridge style like morris9460 posted typically allow full pressure in the tank line.
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD 112
    BX1850 gone but not forgotten
  6. #6
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,482
    JACKSONVILLE, FL
    These valves and sub assemblys do not have or need PB.
    Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
    Surplus Center - 1 STATION DO3 SUBPLATE OPEN CENTER
    4 ports and 5000 psi rating.
    Solenoid valve with a tank port.
    http://www.surpluscenter.com/item.as...name=hydraulic
    The tank port can be pressurized to full pressure if necesary.
    J.J.
    Git er done.
  7. #7
    New Member
    Join Date
    Oct 2012
    Posts
    4
    Gallatin
    Ford 5200
    I had read that, but i was concerned about the valve being able to allow the cylinder on the grapple to drain the non pressure side while applying pressure to the opposite cylinder side simultaneously. to me it seems that it would need another low pressure drainage port, like most pb valves have. I have never physically inspected a solenoid valve, but in my head it would appear that when one side of the solenoid is engaged and diverting high pressure fluid to the desired side of the cylinder, it blocks off the ability of the non pressure side to drain. seeing that there is only one in port and one out port, if the solenoid is blocking the flow there, then how does the low pressure fluid get to the drain port. I could be wrong, and maybe in my head i'm not quite picturing how the valve structure is set up between the ports....
  8. #8
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,482
    JACKSONVILLE, FL
    You have fluid into the IN port, and fluid through the OUT port, and you have two work ports. Same as a single spool valve without PB.
    When you activate the solenoid, the IN fluid goes to one side of a cyl, and the fluid on the other side of the cyl exits the OUT port.
    With no voltage applied, , fluid flows in the IN port and out the OUT port, locking the cyl.
    J.J.
    Git er done.
  9. #9
    Join Date
    Jan 2010
    Posts
    1,875
    Northern, IL
    Branson 2400H
    This in not a true statement for the Vickers valves..
    NOTE: This is copied from Eaton Vickers data sheet GB-C-2015
    Depending on if this is a DG4V-3 as stated or a DG4V-3S which is more common you can have two different tank port pressures.
    Port T code
    Refer to “Operating Data” for port T
    pressure ratings.
    2 – 10 bar (150 psi) for spool position indicator models S3, S4 and S5.
    4 – 70 bar (1000 psi)
    5 – 100 bar (1500 psi) for standard performance models, DG4V-3S, with AC or DC solenoids.
    6 – 207 bar (3000 psi) for AC high performance models, DG4V-3, including spool position indicator type S6.
    7 – 207 bar (3000 psi) for DC high performance models, DG4V-3, including spool position indicator type S6.
    JD 112
  10. #10
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,482
    JACKSONVILLE, FL
    daryng,
    All cyl fluid usually exits the OUT/TANK port, and is low pressure.
    However in a valve with no PB, all fluid will exit the OUT/tank port. If this is the only valve, there will be no or very little back pressure, but if another valve is added downstream, and is activated, this is what cases trouble with back pressure on the OUT port.
    If you use the DO3 subplates from Surplus Hydraulics, you should be safe.
    J.J.
    Git er done.
Similar Threads
  1. speedshift solenoid valve
    By chade1968 in forum Massey Ferguson Owning/Operating
    Last Post: 08-03-2011, 11:32 AM
  2. wiring up a solenoid valve
    By jinmared in forum Parts/Repairs
    Last Post: 03-25-2010, 06:54 PM
  3. HELP PLUMBING SOLENOID VALVE
    By wildwillie in forum Hydraulics
    Last Post: 10-24-2009, 08:01 AM
  4. Grapple How does the solenoid valve to control the grapple?
    By OakHillFarmer in forum Attachments
    Last Post: 08-30-2007, 07:35 PM
  5. Solenoid Valve
    By ifinish in forum Customization
    Last Post: 05-03-2005, 07:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
