Spidermonkeywrench
Just change the rear axle fluid and found my rear brake is leaking a lot if fluid. Anyone familiar with this issue? I cant say as Ive ever seen brakes like this in my life. Maybe I should stick to motorcycles. There is a bolt that threads into a hole on the rear axle (on both sides of the gear housing) and fluid is draining out at about a quart a minute. Not sure if screwing it all the way in will help or exasterbate the issue and Id like to avoid doing donuts if I hit the brakes. Im attaching a pic thats not the greatest but Im pointing at the area.Ling bolt on one end with what looks like a welded washer on the other end. GOD I hope nothing broke (bolt) because my Boss wants his backhoe by Friday and I dont think I can rebuild an entire rear end in 3 days. HELP!!!
