Grapple Switch
   / Grapple Switch #1
Guesseral
Erie Pa.
Montana R4944, Ford Jubilee, Ford 621, Ford 841
Ok I have found my 12VDC selector (diverter) valve the fittings and the hoses all at surplus center no problem. The one piece I can't find is a surface mount SP spring return NO switch for the application. I have found a kit that has a real nice switch but the kit is way more $.
Tractor Electric Diverter Valves
What has everyone else used for the switch? I know many of you have installed this same system set up for your grapples but just what have you used for a switch? I really feel stupid asking this question becaues it is seemingly such an easy item, but I can't find one that fits the application or fits a joy stick!
   / Grapple Switch
Yea I have found many switches that can be recessed on the grip but I was looking for a simple surface switch. I really do like the replacement grip though.
   / Grapple Switch #4
Here's what I used with my fasse valve, which is mounted on the FEL arms on my Kubota. I found a Hurst shifter knob with a thumb button, this would normally be used for a nitrous setup in a car. It was about $40.00 + shipping from Amazon but it's widely available on the net. I also installed a rocker switch in parallel on the dash for when I want it locked into the 2nd outlet. Also installed a set of pilot lights on the valve so it's easy to tell that they're working. I used a bosch relay from the switches to control the power to the solenoids. If anybody needs a schematic and I'll draw one up. DSCF2695.JPGDSCF2696.JPG
   / Grapple Switch #5
What about a simple horn button switch clamped just under your joystick knob? This one is rated at 5 amps. If you need higher current, wire the horn button to a commonly available starter solenoid and use the high current solenoid to power the diverter valve's solenoid.
   / Grapple Switch
I suppose that would work. There are a lot of different buttons that would work, I think I am just to picky! I am looking for a certain look, problem is I don't know what that is! Ever have that feeling.
   / Grapple Switch #7
I have the same switch in your initial link, but I got kine directly from Fasse with my diverter kit. Call them and see if you can just get the switch from them. It has held up well, and I like it. Www.fasse.com if I recall correctly.
   / Grapple Switch #8
Why not contact the diverter manufacturer, Rankin, and buy just a replacement switch from them? They give the part # in the parts breakdown on the PDF .
Or contact Fit Rite Hydraulics, Brian, the owner may be able to give you what you want. He supplied my Top-N Tilt and diverter valve- just like the one you show in your link.
   / Grapple Switch #9
I'd contacted Idaho Implement earlier today about exactly the same thing.
From the reply email: "The replacement switch (part #309-704) from the Rankin kit is $120 + shipping. It has wires for the battery and about a 2' wire lead on it that plugs into an extension (part #309-702 - $27) that connects to the diverter unit. Since these parts are designed for use in conjunction with this particular unit, we would have to sell them "as-is" with no guarantee or warranty for your application."
For $120, I'll keep looking
   / Grapple Switch #10
I'm also waiting for a response from Rankin as suggested by Coyote Machine. I'll post up once I hear back from them
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2006 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2006 OSHKOSH FRONT...
2001 MACK CX SLEEPER (A54313)
2001 MACK CX...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
