Results 1 to 10 of 10
10-29-2012, 05:45 PM #1New Member
- Join Date
- Sep 2012
- Posts
- 12
- Location
- Washington DC
- Tractor
- John Deere 24 Skid Steer Loader
JD24 aux front hydraulic connections
10-29-2012 05:45 PM # ADS
10-29-2012, 06:36 PM #2Veteran Member
- Join Date
- Aug 2010
- Posts
- 2,113
- Location
- South West MI
- Tractor
- John Deere 2030, John Deere 6415
Re: JD24 aux front hydraulic connections
They look like std AG couplers instead of Skid Steer Flat Face couplers
John Deere 2030 JD 245SL Loader
John Deere 6415 mfwd JD 640SL Loader
10-29-2012, 07:16 PM #3New Member
- Join Date
- Sep 2012
- Posts
- 12
- Location
- Washington DC
- Tractor
Do you think I should replace them with flat faced couplers? The male one leaks a bit anyway.
10-30-2012, 10:41 AM #4Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,656
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Most hyd attachments for a skid-steer will have flat face connectors.
They are also easy to keep clean, and most can connect under low pressure, and some under full pressure.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
10-30-2012, 10:53 AM #5New Member
- Join Date
- Sep 2012
- Posts
- 12
- Location
- Washington DC
- Tractor
Thanks. I have a feeling the PO had a log splitter on the front that he powered with this style. I ordered a couple sets for future attachments.
11-05-2012, 08:59 PM #6New Member
- Join Date
- Sep 2012
- Posts
- 12
- Location
- Washington DC
- Tractor
I ran into a bit of a problem. I got these couplers Flat Face Flush Face Skid Steer Hydrulic Coupler Faster 2 Pair | eBay and they appear to be slightly small for my connections. I measured my threading at 14 tpi and a small end taper diameter of 0.725 inches. I'm guessing that's 1/2 NPT which is what I thought 2FFI12 connectors were. Is there any harm in running with an adapter once I figure out the size mismatch?
11-05-2012, 09:43 PM #7Veteran Member
- Join Date
- Aug 2010
- Posts
- 2,113
- Location
- South West MI
- Tractor
Adapter will not be a problem.
11-18-2012, 07:19 PM #8New Member
- Join Date
- Sep 2012
- Posts
- 12
- Location
- Washington DC
- Tractor
I found out that these quick couplers are SAE 8 o-ring connection, so these adapters should work out.
https://www.surpluscenter.com/item.a...tem=9-6405-8-8
03-19-2013, 10:58 AM #9New Member
- Join Date
- Mar 2013
- Posts
- 4
- Location
- Balfour, ND
- Tractor
- JD 4630
are these machine good and how much should i pay$
03-19-2013, 11:07 AM #10New Member
- Join Date
- Sep 2012
- Posts
- 12
- Location
- Washington DC
- Tractor
I like it, but it's probably not for everyone. It's a clutch based machine not hydrostatic drive, so that means maintaining is more involved and can be expensive. I paid $2400 for mine with no bucket and a blown head gasket, but it was already upgraded with quick connect from a more modern machine. That feature along with the front flat faced connectors I put on make it way more useful than stock. Check out the specs here if you want to know more: http://www.deere.com/en_US/docs/cons..._steers/24.pdf
Similar Threads
Hydraulic Connections
By Mark Page in forum Owning/OperatingReplies: 14Last Post: 10-22-2012, 09:41 AM -
hydraulic filter connections - how?
By ERE in forum Kioti Owning/OperatingReplies: 8Last Post: 11-02-2011, 07:54 PM -
hydraulic connections for bh90
By watchdawg in forum Kubota Owning/OperatingReplies: 12Last Post: 05-03-2008, 09:01 PM -
Hydraulic connections question
By fastpat in forum Kioti Owning/OperatingReplies: 3Last Post: 03-23-2006, 03:30 PM -
prepping hydraulic connections
By 44trxfun in forum Parts/RepairsReplies: 9Last Post: 10-28-2004, 07:51 PM
