Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Member Shepp's Avatar
    Join Date
    Aug 2012
    Posts
    47
    Toronto Ontario
    Ford 3000
    Default Re: Ford 3000 hydraulic tap for log splitter
    Quote Originally Posted by art View Post
    Hate to discourage anyone but there were not many people who ever raved about there being enough hydraulic power with that series or grouping of tractors. Most brought there tractor mounted units back in to be replaced with the gas engine units.
    I think the best option would be to mount an independent hydraulic pump on the splitter and drive it with the PTO
    Shepp
  2. #12
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    pto pump willwork great.. need a valve and resevoir.. big $$
    the pump on the engine of the 3000 will work.. but be slowish...
    should have an asc valve .. that and a hose or two and you should be good to go..
    or you could buy the 100$ PB plate and a valve for another hundred... won't gain you any flow over the asc valve.. though.. and ford gave you that free..
  3. #13
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Try this valve on your log splitter. It will increase your speed using regen.
    Prince LSR Rapid Extend Logsplitter Valve - Cylinder Services
    Prince LSR-3060 fast extend
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #14
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,418
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Set it up like this and you only need to run the tractor at about 1500rpm and use ever little fuel.
    Attached Thumbnails Attached Thumbnails Ford 3000 hydraulic tap for log splitter-ag-stuff-037aa-jpg
  5. #15
    Join Date
    Aug 2012
    Posts
    47
    Toronto Ontario
    Ford 3000
    Quote Originally Posted by Leejohn View Post
    Interesting setup. Do you have more pics?
  6. #16
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,418
    Doniphan, Mo.
    No other closeups that you can see how it's under the legs and the pump. You can see the adjuster in that picture and thats about it. I can take some more if you tell me what part you want to see.
  7. #17
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    The picture appears to show about, a 1 to 6 ratio chain drive to the shaft of a high rpm hyd pump.
    540 PTO rpm X a 1 : 6 ratio = 3240 rpm
    Any idea of the pressure and GPM's?
    The GPM's of the pump is variable based on the rpm of the tractor engine.
    J.J.
    Git er done.
  8. #18
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,418
    Doniphan, Mo.
    It's a 3.5 to 1 ratio and the psi is set at 2200. I forgot to look at the spes, on the pump. It has 1" in and out ports so you can just about guess. When working by myself I run at 1500rpm and if I fell good I'll go up to 2000rpm. If I have a helper I'll take her to 2200rpm. With engine wide open it's way to fast.
  9. #19
    New Member
    Join Date
    May 2009
    Posts
    6
    Southwick, MA
    Ford 9600, 5600 & 2810
    Quote Originally Posted by Guesseral View Post
    Now that you mention it , my uncle even said his 9600 ford didn't run his wood splitter so well he got a gas one also.
    Never used my 9600 on a splitter. Use my 2810 and it works fine running at about 1,000 rpm. It's an old Central Tractor splitter. If the 2810 can split, so can a 3000. The 2810 has an after-market kit like this:
    New Hydraulic Remote Kit for Lots of Ford Tractors | eBay
  10. #20
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Quote Originally Posted by HayFarmer View Post
    I never said it didn't run the wood splitter! I said it didn't run it so well, meaning it was slower than slow. But yes it did run the splitter, just not in a very effient mannor!
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
Similar Threads
  1. Mini Splitter Air/Hydraulic Log Splitter
    By BobRip in forum Build-It Yourself
    Last Post: 02-24-2015, 08:00 PM
  2. Ford 1220 with a 3pt Log Splitter
    By ford351c in forum Attachments
    Last Post: 11-17-2009, 10:28 PM
  3. Ford 1220 with a 3pt Log Splitter
    By ford351c in forum Hydraulics
    Last Post: 11-16-2009, 09:24 PM
  4. NAA Ford: Plumbing it for a Log Splitter
    By elvi in forum Hydraulics
    Last Post: 10-07-2009, 07:59 PM
  5. Old Hydraulic Log Splitter
    By Danny_In_Illinois in forum Attachments
    Last Post: 10-17-2007, 02:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
