Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    1
    Indonesia
    JCB
    Question Digging Force
    Hello,
    Has anyone done or heard about any working measurements on cylinder pressures to help calculate actual digging forces?
  2. #2
    J_J
    J_J is online now
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,492
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Digging Force
    The engineers calculate all that data before the device is even built. They also take in the fact that the cyl force may cause problems as to tipping, breakage, and may specify the pressure to stay within the bounders of safe operation.
    If you know the force of the cyl, and the mechanical relationship, you should be able to compute a figure.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Silver Member indianaEPH's Avatar
    Join Date
    Sep 2006
    Posts
    228
    South Central Indiana
    Kubota M59
    John: In order to determine actual digging fore a lot more information would be required. IN addition to the cylinder force the geometry of the hoe/machine is required to calculate the force at the point of contact with the earth. This force will vary as the machine implement position varies. This is called kinematic analysis. There are probably calculators on the net that can help with this but in general it is a complex analysis.
    M59 TLB, 66" HD Grapple, Woods 72" BB, Kubota Trencher, Stump Bucket, Taylor 72" Box Blade, 7 ft back blade, woods 7 ft rock rake.
  4. #4
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,492
    JACKSONVILLE, FL
    If you look at the specs for a loader or a BH, they have already calculated the lift , breakout force, etc, for the attachment.
    If building on your own, and when finished, a hyd pull gage may help you in finding the force.
    For example.
    JCB*3CX 14FT (214)*Loader Backhoe
    J.J.
    Git er done.
  5. #5
    Join Date
    Mar 2009
    Posts
    130
    I have worked for several OEM's in the off road equipment business over the last 18 years and I can tell you that they do lots of calculations before any steel is ever cut. Then we take the prototype and make sure it does what we thought it would do. This includes cylinder forces, structural stresses and tipping capacity.
    As far as calculating forces, it is certainly possible. Some machines, like cranes, do this already. But like indianaEPH said you need sensors to determine the angles of all the joints plus the real time cylinder pressures. In reality there will be some error due to cylinder seal drag and if your machine isn't level.
    ISZ
  6. #6
    Elite Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    4,106
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by johngateley View Post
    It is an interesting question. The calculations are quite easy and I have made them many
    times.
    For years, I have tried to do a fair comparison of backhoe attachments for compact
    tractors. The problem is that the manufacturers typically put digging forces into
    their spec sheets, but don't always tell you what the hydraulic pressures are. Consequently,
    it is hard to do a fair comparison between hoes.
    What I did is measure the dipper cylinder OD, the dipper stick length, and the dipper stick
    arm in the field. I then calculated the cylinder force as well at the "dipper stick ratio". The
    DSR is the ratio of the DS arm to the DS length. The DS arm is the distance between where
    the DS cylinder attaches to the DS, and the DS pivot point. I then calculated the digging
    force at the bucket pivot in the maximum case. The max is where the DS arm is perpendicular
    to the boom.
    Well, Excel is a wonderful tool, and I made a spreadsheet with the formulae entered. Here
    is a snapshot for some of the hoes I have measured. Note that I am able to compare them
    using 2 different hydraulic pressures 2000 and 2500psi. I had to estimate the cylinder IDs if
    I did not have that info. Cyls of this type usually have about 0.2" wall thickness.
    Also note that I have ignored the "breakout force" calculation. The BF depends on the
    bucket geometry (length of bkt pivot to end of tooth).
    See my TBN projects at:
    http://mysite.verizon.net/resyfcgt/
  7. #7
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,492
    JACKSONVILLE, FL
    One reason for the lack of pressure statements is that the pressures are changing all the time when using the attachment as to the load imposed on the bucket, and other components in the attachment.
    The load factor determines the pressure.
    You could figure for max relief setting on the BH relief valve or loader relief valve for max force.
    If you change buckets, the figures for the loader and or BH may change.
    J.J.
    Git er done.
  8. #8
    Join Date
    Feb 2004
    Posts
    4,106
    NorCal
    Quote Originally Posted by J_J View Post
    All manufacturerers quote max digging force using the dipper, and using the bkt cyl (the
    breakout force). Some of them state the test conditions (hydraulic RV setting). Some
    don't. Hard to make a comparison when shopping by spec sheet.
    The max forces are what we are all interested in, and that's partially determined
    by the RV setting, assuming there are no upstream RVs set lower. In using a backhoe,
    the user hits the RV setting on many, if not most strokes when digging a
    new hole.
  9. #9
    Join Date
    Mar 2009
    Posts
    130
    As far as breakout force goes, all manufacturers with use whichever combination of cylinders gives them the higest numbers. But where it gets a little shady is with which bucket? They will use the shortest bucket they "sell" so they can publish the biggest number.
    For example, when I was working on skid steers, I was told that John deere does their capacity ratings with a small bucket designed only for foundry use. This keeps the CG of the load close to the front wheels and decreases the tipping moment, which increases the rated load. We could never prove this, but otherwise their numbers don't jive. Granted it doesn't up the numbers a lot, but some people just go off of the spec sheets.
    ISZ
  10. #10
    Join Date
    Feb 2004
    Posts
    4,106
    NorCal
    Quote Originally Posted by IceStationZebra View Post
    Yes, they do, and they kinda have to if they have nothing else to go by.
    The bucket variable is why I did not even consider breakout force to campare hoes.
    It is hard to hide the force capabilities of the dipper. So a fairer comparison is
    possible.
    The other things I look at to compare are the diameter of the pins, the width of the
    dipper at the bkt pivot, and other design choices that add to the hoe's strength. One
    indicator of strength is the weight of the unit, sans bucket. That spec is not always
    published either.
Similar Threads
  1. How do you calculate digging force requirements?
    By jgibbens in forum Build-It Yourself
    Last Post: 03-08-2012, 01:03 PM
  2. Does digging force equate to lifting force?
    By MrWhippy in forum Attachments
    Last Post: 10-21-2011, 08:09 AM
  3. What's a dipperstick digging force?
    By back2earth in forum Owning/Operating
    Last Post: 05-18-2009, 12:37 PM
  4. BX24 digging force
    By jgjones in forum Kubota Owning/Operating
    Last Post: 04-11-2008, 05:27 PM
  5. Backhoe Backhoe digging force
    By John4652 in forum Attachments
    Last Post: 09-02-2002, 03:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
