Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    Default Re: Kubota L3130 Hydraulic accessory block
    To better inform what I have been doing, here is the loader we are using, ( yes a JD ) loader, but my friend got what he though was a decent deal, and though it was a cut and dry install, though we knew we had to make up the new mounting brackets and that was the most difficult to do, we've had it on and all will work fine as far as clearance as well as fitting, the control valve easily accessible up on the tower, with plenty on line to reach under the floor board to the accessory block,
    Attached Thumbnails Attached Thumbnails Kubota L3130  Hydraulic accessory block-3128438_large-jpg   Kubota L3130  Hydraulic accessory block-3128439_large-jpg   Kubota L3130  Hydraulic accessory block-3320-8-jpg   Kubota L3130  Hydraulic accessory block-502476-p1010004-jpg
    Never judge a man until you've walked a day in his shoes,
  2. #12
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,387
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    You are getting all mix up. All three of your pictures it shows the cover plate that has to come off. It takes a 12mm wench and it was posted before that the holes under that plate was threaded, I'm not sure about that, if not you have to make or buy a new plate. It's not called a accessory block , it's called hydraulic outlet block look under that in the parts manual.
  3. #13
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,387
    Doniphan, Mo.
    I was writing at the same time as you were posting. I'm talking about the 1st pictures you posted. The way you are headed is the hard way. But It can be done.
  4. #14
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    That hyd block is there for a reason. Locate the cover cap with threaded holes.
    You could also cut the line from the pump and install the loader valve in series. Then the loader valve will provide the relief pressure.
    Right now, your tractor relief is on the bottom of the hyd block.
    Send this picture to Messnicks and tell them you want the hyd block with threaded ports for your tractor..
    http://www.tractorbynet.com/forums/a...6-p1010004.jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  5. #15
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    I've not opened the side cover yet, But will do so when I get over to the tractor again, so You think there could be a possibility of threaded holes inside that will provide a connection? did I mention the 3130 is dt and Gst? along with Power steering of course, I could cut into the lines directly off the pump but would this lower the pressure needed for the transmission and PS or is the trans. & PS on a total circuit of their own?
    so I guess before I go any further I should look inside the cover cap, Right!
    Thanks
    Tim
  6. #16
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Your tractor hyd pump supplies flow for power steering and implements.
    Transmission has it's own pump.
    Implements 8.3 GPM
    Power Steering 4.9 GPM
    Total pump GPM is 13.2
    Does your friend have a manual for the tractor?
    J.J.
    Git er done.
  7. #17
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,387
    Doniphan, Mo.
    Well David_Kb7 said there was some threads. I never had the hoses off of mine and don't have it any longer, so that is why I said not sure about the threads. I would forget about hooking at the rear that is for rear remote Hyd outlets. The hydraulic outlet block is the same on Hst and the gst as for as the cover plate. Don't cut any hard lines you don't need to.
  8. #18
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    No manual... which has really made it more challenging to do this task not knowing much about the tractor, heck I didn't even know it was hydrostat driven, if had I known before 3/4 way into this I might would have discouraged him not to have bought it, ..... so far he's into this project for about $2,500 in the beginning He asked if it would work.. and if he bought it would I help him to hook it up.... I did a quick visual of his tractor looked underneath and found what I thought looked to be a FEL connection port, So my answer was yes I'd help, I've only has experience in installing my own FED, and even then I had the help of JJ and few other members, all was successful, with one exception I won't go into.
  9. #19
    Veteran Member David_Kb7uns's Avatar
    Join Date
    Aug 2005
    Posts
    1,766
    Willamette Valley Oregon
    Kubota X 4
    The cover that is on the tractor now just has the ports tied together, the block that bolts in place of the cover isolates the ports and connects them to threaded ports that go to lines for the hydraulic valve.
    You need to go to the dealer and have a good parts guy dig for the number for that block. The block is a US made part and you may have to check on the whole goods side to find it as it is part of the loader install package. The block you found under the option section is for the rear hydraulic remotes and not suitable for loader connection.
    David Kb7uns
    Grand L3130GST LA723 Loader, ATI grapple, ATI grapple bucket, WR Long front remote, Kubota rear remotes, Bradco 408 Backhoe with thumb, 60"KK brush hog, 60" RM Finish Mower, Speeco Post Auger, 72" KK rear blade, 60" box blade
    BX2230 LA211, RCK60, GCK60 Bagger,42"Land Pride Tiller, XB BB, XB RB, rake, Fimco 3PT sprayer
    G2160 RCK60 Mower
    RTV1100 Orange, Work Lights, Front Rear Winch,Rear Screen, High Mount air cleaner, water seperator
    2010 Polaris RZR 800 S
    2007 CAN AM Outlander 800 LTD
  10. #20
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    Update:
    I've contacted the Local kubota dealership/service center, The parts person said it might be possible they have the part in stock, But to be certain we're talking about the same part I must talk with the shop forman, the actual person who sets up and service their tractors, So I'm awaiting his call and keeping my fingers crossed they have what we need,
    Thanks
    Tim
Similar Threads
  1. Replies: 4
    Last Post: 07-25-2011, 10:17 AM
  2. Kubota L3130 engine block needed
    By FTCKUBOTA in forum Kubota Owning/Operating
    Last Post: 09-13-2009, 10:24 PM
  3. Kubota B7800 Hydraulic Block
    By tamarack in forum Kubota Owning/Operating
    Last Post: 06-17-2008, 01:14 PM
  4. Check Kubota L3130 Hydraulic Pressure
    By smittyd3 in forum Hydraulics
    Last Post: 11-09-2005, 08:10 PM
  5. Check Kubota L3130 Hydraulic Pressure
    By smittyd3 in forum Parts/Repairs
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
