Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    18
    skiatook oklahoma
    2002 century 2028
    Unhappy 2028 century hydraulics quit working
    i have been using my tractor moving tree limbs when all my hydraulics quit working front end loader and box blade will not lift i changed fluid and filter still nothing any clues to what went wrong and how to resolve?
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: 2028 century hydraulics quit working
    Check your pump to see if it's turning.
    Use a hyd gage and check your pressures.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    New Member
    Join Date
    Nov 2012
    Posts
    18
    skiatook oklahoma
    2002 century 2028
    thanks j_j my pump on this model is gear driven and also runs a separate pump for power steering which is working fine but has a seperate reservoir
  4. #4
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,305
    Northern, IL
    Branson 2400H, JD X540
    Is it possible you could have hooked one of the hoses with a tree branch and partially unplugged one of the quick disconnects.
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD X540
  5. #5
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Remove a complete QD fitting from the hose going to the first QD and place in a bucket and see if you have hyd flow.
    If so , check the hyd pressure.
    J.J.
    Git er done.
  6. #6
    New Member
    Join Date
    Nov 2012
    Posts
    18
    skiatook oklahoma
    2002 century 2028
    took high pressure line off feed block to front end loader nothing there guess pump went out
  7. #7
    New Member
    Join Date
    Nov 2012
    Posts
    18
    skiatook oklahoma
    2002 century 2028
    does anyone know what make the hydraulic pump is on a century tractor 2028? cant find the name on pump
  8. #8
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,833
    Hooksett, NH
    Kubota B2320
    Check the spline, keyway or coupler to make sure it's turning the shaft
    Pix..??
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  9. #9
    New Member
    Join Date
    Nov 2012
    Posts
    18
    skiatook oklahoma
    2002 century 2028
    Didnt know if i wanted to tear it apart if i couldnt find another pump if i needed it
  10. #10
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,305
    Northern, IL
    Quote Originally Posted by rogerdodger View Post
    I looked at the parts breakdown on the bBranso sight and all it says is 13 cc. I have looked at my Branny 2400 and can not find a number on it either. I would suspect the drive shaft is spline so it is possible the splines are worn or a coupling has slipped. I couldn't tell were or how the pump is mounted but if out in an accessable area where you don't have to drain the tranny I would remove the pump and look for obvious damage. Gear pumps are usually pretty tough so suspect something in input drive broke.
    JD X540
Similar Threads
  1. century 2028
    By littleman1 in forum Century & Branson
    Last Post: 09-12-2011, 12:39 AM
  2. Century 2028 F/S
    By MyOutdoors in forum Century & Branson
    Last Post: 09-07-2004, 12:21 PM
  3. Century 2028
    By RamTruckMan in forum Century & Branson
    Last Post: 03-04-2004, 05:13 PM
  4. Century 2028 used
    By Jim_in_Omaha in forum Century & Branson
    Last Post: 02-01-2004, 02:58 AM
  5. Century 2028
    By StevieWonder in forum Century & Branson
    Last Post: 08-18-2003, 11:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
