Homemade Log Splitter Hydraulic Diagram
   / Homemade Log Splitter Hydraulic Diagram #1
unixkid
turnersville, NJ
kubota
I'm going to attempt to attach a diagram to this post, if it is successful please comment on it pertaining to: it won't work, will work, this should be changed, your forgetting about this, etc.
I left the cylinders out for now.
Thank you,
-unixkid
   / Homemade Log Splitter Hydraulic Diagram #2
That should work . Everything looks correct.
   / Homemade Log Splitter Hydraulic Diagram #3
you might consider a filter base that includes a filter bypass over a preset pressure. that way you dont blow up the filter on those 0 deg F mornings when you want to go out and split some wood and that 30wt oil is the consistiancy of molasis.
Thanks for the responses
I did not see them but they are something I've been looking for. I saw a similar one for a regular valve on another website but not one for the autocycle valve with the explanation on its workings. Thanks for the links, I saved them locally to my hard drive for future use in case my internet connection is down.
-unixkid
