Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Join Date
    Apr 2011
    Posts
    115
    Warren PA
    JD 5425 w/542 Loader
    Default Attaching truck sno plow to tractor FEL, hydralic connections
    I am mounting an old Fisher truck plow my FEL, i have the mount complete and am in the process of trying to get the hydralics to work. The plow has two single action hydralic cylinders so i ran two hoses from the tractor's rear hydralic valves to the front of the loader arms, then i installed short sections of hose to the cylinders and placed quick disconnects between the hoses. The first attempt to rotate the blade worked fine but after cycling the blade a couple of times it froze up and would not rotate either direction. When i checked the cylinder hoses both were pressurized so i couldn't get the quick disconnects apart, i bleed the pressure off by loosening the threaded connectors at the cylinders. If i leave one cylinder hose disconnected i can pressurize the other cylinder and get the blade to rotate, but if i connct the hose and try to rotate the blade back the other direction both cylinders pressurize and the blade locks up again until i bleed pressure off of one of the cylinders.
    I mounted the quick disconnects with the female part on the plow and the male part on the hose from the tractor's remote valve. Is there a specific orientation for which end goes on which hose?
    I am lost for a solution, as recommendations will be greatly appreciated.
    Thanks for any help.
    Dave
  2. #2
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    limerick pa lycoming county pa
    kubota bx23
    Default Re: Attaching truck sno plow to tractor FEL, hydralic connections
    When you pressure one side the other has to go to the tank or drain side to relieve the pressure as blade moves over.
    what kind of tractor and valves are you using?
    the valve should be
    handle pulled A port pressurize B port to tank
    release handle both ports blocked (if its open center flow will go to tank)
    push handle B port pressurize A port to the tank/
    Take some pictures and post them too they are worth 1000 words.
    and eliminate 2000 questions.
    tom
    If it ain't broke we will help you brake it
    If it is broke we will help you get it fixed!
    https://www.facebook.com/joseph.t.mussington
  3. #3
    Platinum Member Notforhire's Avatar
    Join Date
    Nov 2011
    Posts
    853
    Southwestern Virginia
    JD 5055E
    I'm glad you posted this! I am interested in using snow plow cilinders to angle my york rake.
    Bill
  4. #4
    Join Date
    Apr 2011
    Posts
    115
    Warren PA
    Tom,
    Thanks for the reply. It is a John Deere 5425, i am not sure about the valves they are the standard remote valves on the rear of the tractor. I had one cylinder hose hooked to the Cylinder Extend port on the tractor and the other cylinder hooked to the Retract Port. These are the same ports i use to hook my discs and baler hydralic cylinders to so i know they work, the difference is they are dual action cylinders.
    Attaching truck sno plow to tractor FEL, hydralic connections-hydrocyl-jpg
    Hydro Cylinder Connection
    Attaching truck sno plow to tractor FEL, hydralic connections-plow-jpg
    Plow connection to loader
    Attaching truck sno plow to tractor FEL, hydralic connections-quickcon-jpg
    Quick Disconnectors
    Attaching truck sno plow to tractor FEL, hydralic connections-remotes-jpg
    Hose Connection to tractor remote
    Thanks again,
    David
  5. #5
    Join Date
    Apr 2011
    Posts
    115
    Warren PA
    Quote Originally Posted by Notforhire View Post
    Bill
    Bill,
    From my current experience with single action cylinders i would use double action cylinders for your project, unless you already have the snow plow cylinders.
    Dave
  6. #6
    Join Date
    Nov 2011
    Posts
    853
    JD 5055E
    Quote Originally Posted by dlauffenburger View Post
    Bill,
    Dave
    I already have the cylinders. A friend gave them to me years ago. I don't understand why your setup doesn't work. I guess that's not surprising, I know little about hydraulics.
    Best, Bill
  7. #7
    Super Member
    Join Date
    Aug 2004
    Posts
    6,835
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    As I understand the Fisher system, combined the 2 single action cylinders act like one double action.
    You pressure one and the other dumps back to tank. I always think of them actually being joined as one so I'd connect just like a double action cylinder.
  8. #8
    Join Date
    Nov 2011
    Posts
    853
    JD 5055E
    Quote Originally Posted by PILOON View Post
    It looks, to me, anyways, that the OP has done that.
    I do agree with your theory, but then again, what do I know?
  9. #9
    Super Member
    Join Date
    Feb 2002
    Posts
    5,350
    western,pa.
    Kioti DK 35
    Thats how my Western snow plow works.
    I hook up my 2 single acting cylinders to the rear remotes just like I would 1 double acting cylinder and my snow plow works fine.
    Vince,
    Kioti DK 35
    Hustler Super Z
  10. #10
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    Kubota B2410, Kubota B7100Dt, Kubota B7100HST
    Can you try the setup without the quick disconnects? Just get the correct fittings and join the hoses together. My guess is that you will find it works OK without the quick disconnects. Once you find out if I am correct you can look for the problem in the disconnects.
Similar Threads
  1. truck plow to tractor plow
    By Builder in forum Attachments
    Last Post: 09-17-2013, 09:42 PM
  2. Attaching Meyers plow to the front of my tractor..
    By wetstuff in forum John Deere Owning/Operating
    Last Post: 04-15-2011, 05:56 AM
  3. Another truck plow on tractor
    By JB4310 in forum Build-It Yourself
    Last Post: 11-27-2008, 10:08 AM
  4. truck sno plow mounted to fel
    By MAYOR8020 in forum Hydraulics
    Last Post: 12-18-2007, 04:35 PM
  5. Convert Sno-way plow?
    By johnnylight in forum Customization
    Last Post: 10-26-2006, 12:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
