Results 1 to 3 of 3
12-08-2012, 11:31 PM #1New Member
- Join Date
- Dec 2012
- Posts
- 2
- Location
- Conway, SC
- Tractor
- 3320 2012 JD
hydraulics
could someone help me, I have a 3320 JD with mid scvs can I run a hydraulic top link off these,
12-08-2012 11:31 PM # ADS
12-09-2012, 08:40 AM #2
Re: hydraulics
Yes you can, just run long hoses to the rear.
BUT: Why not get the 3rd SCV kit? You already have the valve, the kit includes the WD's, hardlines, lever, brackets and hardware to control it.
This is for the older non-CAB model (you need to know your serial number to order):
Third Scv Kit ( - 710000)
Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
1 LVU14087 Knob 1
2 LVU13368 Label 1
3 LVA11953 Lever 1
4 LVA13145 Hydraulic Line 1
5 LVA13144 Hydraulic Line 1
6 R26375 O-Ring 2
7 M42702 Snap Ring 4
8 14M7396 Lock Nut 3 M8
9 19M7867 Bolt 3
10 LVA13231 Coupling 2 1/2"
LVA12997 Coupling 2 (A) 3/8"
11 AW28043 Kit 2 DUST CAP AND PLUG
12 LVU11998 Bracket 1
13 M801935 Clamp 1
14 TY22467 Clamp 1
15 61M5003 Adapter Fitting 2
16 51M7043 O-Ring 1 15.300 X 2.200 MM
17 38H5003 Adapter Fitting 1
18 T77857 O-Ring 1
19 24M7088 Washer 1 6.600 X 12 X 1.600 MM
20 24M7047 Washer 1 13 X 24 X 2.500 MM
21 M137418 Bushing 1
22 LVU11342 Pin 1
23 11M7059 Cotter Pin 1 3.200 X 20 MM
24 M112711 Spring Pin 1
25 R128357 Pin 1
26 19M7862 Screw 1 M6 X 20
27 LVU22298 Rod 1 SUPPORT THIRD SCV
28 LVB25506 Kit 1 (NLA) THIRD SCVLast edited by kennyd; 12-09-2012 at 06:22 PM.
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
12-09-2012, 04:14 PM #3New Member
- Join Date
- Dec 2012
- Posts
- 2
- Location
- Conway, SC
- Tractor
- 3320 2012 JD
Re: hydraulics
Thanks for the reply,I was hoping I could.
Similar Threads
need help with hydraulics
By joe woodum in forum Mitsubishi/SatohReplies: 6Last Post: 07-21-2010, 11:50 PM -
Hydraulics
By CCoron in forum HydraulicsReplies: 0Last Post: 05-15-2010, 04:58 PM -
No hydraulics
By tnbowhunter in forum YanmarReplies: 12Last Post: 05-03-2010, 12:10 PM -
no hydraulics
By Spruce1975 in forum IsekiReplies: 1Last Post: 11-21-2004, 08:47 AM -
Remote Hydraulics: Impact On Overall Hydraulics?
By Ursushorribilus in forum AttachmentsReplies: 5Last Post: 10-14-2004, 04:44 PM
