Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member
    Join Date
    Feb 2011
    Posts
    36
    PA
    Kubota M59
    Default Kubota M59 front hydraulics for snowplow?
    Can I use the front auxiliary hookups to power angle my western plow? Or do I need a diverted or flow control valve(s)....
  2. #2
    Member
    Join Date
    Feb 2011
    Posts
    36
    PA
    Kubota M59
    Default Re: Kubota M59 front hydraulics for snowplow?
    Got the answer! The front auxiliary hooks work the power angle on the plow with no flow control needed. The angle works faster than a normal set up, but still works great. Only modification needed was adapting the fittings
  3. #3
    Elite Member zzvyb6's Avatar
    Join Date
    Dec 2006
    Posts
    3,596
    michigan
    jd 1070
    A flow restrictor of some sort is helpful. I use automotive brake hoses. The small line size does the job perfectly.
    There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
  4. #4
    Veteran Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    1,470
    Livingston County, Michigan
    Kubota M8540, ZD1211 60"
    Quote Originally Posted by zzvyb6 View Post
    Did you use steel braided brake hoses or or regular rubber brake hose?
    Dave
  5. #5
    Member
    Join Date
    Feb 2011
    Posts
    36
    PA
    Kubota M59
    They better be steel braided for the cost of them��. How can I tell??
  6. #6
    Join Date
    Dec 2012
    Posts
    1,470
    Default
    Stainless braided would not have a black rubber coating. I'm not sure about after market hoses but OE rubber brake hoses are not compatible with mineral oil based fluids. It will destroy the rubber. I work in brake development and have seen the results of people who put motor oil, trans fluid, power steering fluid, etc in the master cylinder reservoir, several thousands $ . It would be best to have napa or other company make you a set small diameter hydraulic hoses or run just run it through some brake pipe
    Dave
    Dave
  7. #7
    Member
    Join Date
    Feb 2011
    Posts
    36
    PA
    Kubota M59
    Kubota M59 front hydraulics for snowplow?-image-jpg
    Here's a pic. I got them made at our local tractor dealer and explained what they were for. I'm going to look at them tonight again. Thanks for the advice though!!
  8. #8
    Join Date
    Dec 2012
    Posts
    1,470
    Default
    If you had them made at your dealer they are hydraulic house rated for the right fluid their is probably a steel braid in the rubber. Which you can not see
    Dave
    Dave
  9. #9
    Member
    Join Date
    Feb 2011
    Posts
    36
    PA
    Kubota M59
    Thanks again!
  10. #10
    Join Date
    May 2004
    Posts
    882
    Harpers Ferry WV
    Kubota L4330, 6 rear remotes
    cushion valve in circuit can be a lifesaver
Similar Threads
  1. M59 hydraulics got slow and weak.
    By Hersheyfarm in forum Kubota Owning/Operating
    Last Post: 07-29-2017, 05:23 PM
  2. M59 front hydraulic question
    Last Post: 06-29-2011, 07:27 PM
  3. Snowplow front bucket replacement
    By jnporcello in forum Customization
    Last Post: 10-04-2010, 10:47 AM
  4. Hydraulics for 430 FEL snowplow conversion
    By mlip in forum John Deere Owning/Operating
    Last Post: 11-03-2006, 12:04 PM
  5. Front snowplow bracket help
    By hazmat in forum Build-It Yourself
    Last Post: 12-07-2003, 10:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
