Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    2
    manlius, ny
    955 deere
    Default 955 deere tractor with 300 x loader
    have a deere 955 tractor with a 300 x loader. float position on the scv will not work ? just put sno blade on and loader arms will not float ?
    Bought this tractor in spring.nice shape low hours on it. is scv float adjustable ?
    would defective couper connections affect the float part ? hydraulics seem to have good pressure etc. 3 point works fine.
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: 955 deere tractor with 300 x loader
    Does raising and lowering the lift arms work normal ?
    Try this. Raise the lift arms about half way, then tilt the bucket down, and then lower the lift arms so the wheels are off the ground.
    Then, push the lever to full fwd past the soft stop.
    If none of that worked, remove the bottom cap from the float spool on the loader valve, inspect and clean.
    There are balls and springs on the end of the spool under the cap. Clean the detent groove.
    Float is not adjustable.
    Float means all ports on the float spool are open to tank, and the bucket will follow the ground contour.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Murph
  4. #4
    New Member
    Join Date
    Dec 2012
    Posts
    2
    manlius, ny
    955 deere
    Smile Re: 955 deere tractor with 300 x loader
    JJ: The lift arms work fine lowering and raising. I will try what you recommended this afternoon before the 20 " of snow gets here.
    will let you know.
    thanks for the suggestions.
    easymike
    Quote Originally Posted by J_J View Post
Similar Threads
  1. john deere 300 loader backhoe
    By pago52 in forum Hydraulics
    Last Post: 04-21-2012, 11:23 AM
  2. 300 john deere loader with back hoe
    By nitetrain9 in forum Parts/Repairs
    Last Post: 04-06-2012, 05:38 PM
  3. 1970 john deere 300 loader/backhoe
    By naddrof in forum John Deere Lawn & Garden
    Last Post: 02-16-2010, 04:50 PM
  4. John Deere 300 Loader and JD 790
    By TerryWorkman in forum John Deere Buying/Pricing
    Last Post: 02-12-2005, 11:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
