Results 21 to 30 of 45
01-05-2013, 11:37 PM #21Super Member
- Join Date
- Mar 2008
- Posts
- 6,498
- Location
- Northern Fingerlakes region of NY, USA
- Tractor
- Kubota L3830GST, B7500HST, BX2660
Re: Electric over hydraulic remote setup?
The problem is that if you have the 3 point set to go up while the grapple is closing, the grapple might not close until it is pushing out with enough force to lift the 3 point. See Hydraulic valve power beyond or high pressure carry over for some diagrams on how it works. If you look at your loader valve, it should have 7 ports (4 work ports and 3 other ports).
Aaron ZIf mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
John Stuart Mill
01-05-2013, 11:42 PM #22Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,897
- Location
- 4000\' mountains of Southern California
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Take some good pictures of the back above the 3pt so we can see where we might be able to install the other valves and or the QD ends if you go that way. Are you against making a mount off of the ROPS to place some manual valves and maybe a plate in back to mount the QD outlets? The EX3200 is a clean little tractor and we should be able to come up with a very nice setup for it.
01-06-2013, 09:52 AM #23Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
I dont use both at the same time, grapple and 3pt. However if I try to lift the 3pt with the grapple installed it doesnt lift any real weight untill the grapple either opens or closes (depending on which way I have my hoses connected) OR if I hold the handle of the grapple in the center to allow pressure to the 3pt. Anytime I raise the 3pt the grapple lever will move and stays in position untill the 3pt hits the height my control lever wants it at. Pictures will be here today as soon as I get to the shop.
01-06-2013, 09:56 AM #24Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
Well, no but I got excited when I saw your picture thinking there may a more suitable way to save space and hydraulic hose. If anything a two spool valve would likely be just fine, I probably will never need the extra remote for anything. And to be honest the grapple remote will be open to use when the grapple bucket isnt on, so two would be just fine actually now that I really think about it.
01-06-2013, 01:30 PM #25Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
01-06-2013, 01:33 PM #26Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
01-06-2013, 02:34 PM #27Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
The log splitter valve is probably not a good choice for the grapple, if it does not have a PB port and connected correctly.
The action of one valve should not affect the log splitter valve if the log splitter valve is connected correctly.
If your log splitter valve only has 4 hoses, then it is not a PB type valve, and you run the risk of damage.
You should probably remove the log splitter valve and install a three spool valve for the remotes., and use one of the spools for the grapple, or add a diverter valve to the front curl circuit, and us the joystick curl circuit for the grapple. .J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
01-06-2013, 07:42 PM #28Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
I guess im trying to wrap my head around the 5th hose thats suppose to be coming out of the valve, I understand its to go back to the tank but thats about it. I've tried reading a few things about the subject buts its just not clicking in my head. Cub makes a rear remote kit for this tractor, part kit number RR300.
Here is the parts breakdown:
Parts and Diagrams for Cub Cadet RR300 Rear Remote
It doesnt look all that extensive really. I wish I could get an instruction sheet PDF to see how and where to install this "5th line" to go back to the tank. Everything is so jambed packed under the tractor I dont really know what i'm looking at.
01-06-2013, 07:58 PM #29Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,485
- Location
- JACKSONVILLE, FL
- Tractor
That link does not work for me.
On most single spool valve, you would have an
IN port -from pump
OUT port- cyl expended fluid to tank
work port A - to cyl
Work port B - to cyl
Maybe a PB port - to down stream valve
All return lines should go to tank.
Return hoses can be teed together.
Can also run it into the fill cap.J.J.
Git er done.
01-06-2013, 08:52 PM #30Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,897
- Location
- Tractor
I might be wrong, but looking at how the line runs, I don't think that you need a valve with power beyond. I think that you can just run the pressure line from the left side of your loop to the pressure port on a valve and then have the tank line off of the valve go back to the right side of the loop. I'm thinking that the side marked return just dumps into the tank and does not go any place else. If this is the case, then you do not need the 3rd power beyond line that has been talked about.
Similar Threads
Alternative for remote controlled valve (cab setup)
By jim_wilson in forum HydraulicsReplies: 26Last Post: 10-06-2012, 07:46 AM -
Help with BX hydraulic line setup
By flynifr in forum Kubota Owning/OperatingReplies: 2Last Post: 11-03-2011, 11:58 PM -
For Grapple, Diverter setup or Rear remote?
By andrewj in forum ProjectsReplies: 17Last Post: 01-14-2006, 03:41 PM -
Need help with rear remote setup on a JD 4300
By Anonymous Poster in forum CustomizationReplies: 6Last Post: 03-14-2003, 08:51 PM -
Electric Fencing (remote)
By pdxman in forum Rural LivingReplies: 2Last Post: 12-20-2000, 10:14 AM
