Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    New Member
    Join Date
    Jan 2013
    Posts
    8
    Sri Lanka
    MF-135
    Default Re: How can I attach verge flail mower to my tractor?
    Dear friends
    I am here with sending the photos of my Massey Ferguson 135 tractor. And you can read the PDF of MF hydraulic manual by following link.
    Thank you very much.
    http://www.google.lk/url?sa=t&rct=j&...57700187,d.dGI
    Bandara.
    How can I attach verge flail mower to my tractor?-mf-135-1-copy.jpgHow can I attach verge flail mower to my tractor?-mf-135-2-copy.jpgHow can I attach verge flail mower to my tractor?-mf-135-3-copy.jpgHow can I attach verge flail mower to my tractor?-mf-135-4-copy.jpgHow can I attach verge flail mower to my tractor?-mf-135-5-copy.jpgHow can I attach verge flail mower to my tractor?-mf-135-7-.jpgHow can I attach verge flail mower to my tractor?-mf-135-8-.jpgHow can I attach verge flail mower to my tractor?-mf-135-9-.jpg
    Attached Thumbnails Attached Thumbnails How can I attach verge flail mower to my tractor?-mf-135-6-copy.jpg
  2. #12
    Join Date
    Feb 2012
    Posts
    198
    Albany OR
    Case 580B, Long 460, Allis-Chalmers 160
    OK, just a couple more things - can you edit one of your pics to point to whatever you use to control your trailer lift? I'm thinking the smaller lever opposite the 3-point controls, but not sure.
    Also, the manual in the link has even worse pictures than one I paid for for my Allis-Chalmers, in other words pretty useless. I'm not at all familiar with Masseys other than in general, so we'll need to find your hydraulic pump (another picture please) and figure out where your hydraulic lines go from there - both the output, pressure line and the return line.
    Your new valving will need this info so you can get it connected right... Steve
  3. #13
    New Member
    Join Date
    Jan 2013
    Posts
    8
    Sri Lanka
    MF-135
    This lever controls both 3Pt.and trailer lift. Output and return come through the same hose. To lift the trailer the 3pt. must in up position. When the 3pt.in down position we can稚 get a pressure from the trailer lift line. Go to bellow link. My tractor has not a diverter valve like this.
    Thank you
    Massey Hydraulic System TS300 Hydraulic Selector, isolator assembly
  4. #14
    Join Date
    Nov 2011
    Posts
    192
    Canton, TX
    JD 301A and yanmar YM2500
    Default
    If you trace the trailer connection back to the controlling valve they may have already installed a diverter valve. That part you referenced appears to be an add on to get additional hydraulic functions. You would have to use a service manual to find out where the panel the link references is located and how to install it.
  5. #15
    J_J
    J_J is online now
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,467
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    The pictures are very poor, but it would appear that if you remove that plate you would then install a two spool valve and then have the ability to operate two cyl at the rear.
    The two spool valve would sit where the cover plate sat, and two sets of outlets goes to the back with QD's.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  6. #16
    New Member
    Join Date
    Jan 2013
    Posts
    8
    Sri Lanka
    MF-135
    Thank you J.J ,Steve, medic,
    Your advices are great.
  7. #17
    Join Date
    Apr 2011
    Posts
    582
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Here are some options for a valve that will bolt right to the hydraulic cover plate. They are not cheep but they are easier than tryying to modify existing hydraulic tubes.
    Remote Hydraulic Valve
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  8. #18
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,467
    JACKSONVILLE, FL
    Good find.
    Looks like everything he needs to add on to his hyd system.
    That double spool valve kit will allow you to operate a FEL, T-N-T, or operate two cyl on a wagon.
    J.J.
    Git er done.
  9. #19
    Join Date
    Apr 2011
    Posts
    582
    Erie Pa.
    Yea the bottom one would do everything and it seems that the 3pt hitch would also work at the same time.
    Quote Originally Posted by J_J View Post
    Good find.
    Montana R4944
Similar Threads
  1. Biggest Flail Mower for 50 hp Tractor?
    By UpstateFarmer in forum Ag Tractors & Machinery
    Last Post: 03-05-2012, 07:35 PM
  2. Replies: 0
    Last Post: 08-03-2011, 04:08 PM
  3. Flail Mower Advice Needed - Small Boom Flail Mower for 49HP Tractor
    By Darrenmv in forum Attachments
    Last Post: 08-07-2010, 01:39 AM
  4. Anything like a side flail mower for compact tractor?
    By jinjimbob in forum Kubota Owning/Operating
    Last Post: 08-05-2010, 07:35 PM
  5. Flail Mower Smaller Flail Mower for 25 hp tractor?
    By ammodram in forum Attachments
    Last Post: 06-24-2008, 09:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
