Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    10
    New castle, CO
    Kubota L245DT
    Default FEL Control Question
    Hello, first post here. I've posted this on another forum but thought I'd run it by hear and see if I can get more feedback. Long story short, I've had issues with my 3pt hitch lifting on a kubota L245. I've narrowed the issue down to my FEL circuit. If I bypass the FEL circuit at the block that feeds it by just taking a small section of hose and looping it from the loader hyd. supply and return - the hitch lifts fine.
    So, I tore the FEL control valve apart - o rings looked good and cleaned out the relief valve. Still having the same issue. Which leads me to my question... There's three hoses connecting to the controller; excluding the hoses that connect to the FEL cylinders. Here's a picture:
    FEL Control Question-image-jpg
    If I have them mounted correctly, the left one is 'supply in' from the block, right bottom is 'supply out' back the block, right top goes to top of tranny case. The plumbing within the valve suggest that the 2 right hoses always have access to each other's fluid, with no valve control regulating the flow between the two. If fluid is freely going to the tranny through the return, how can it supply power beyond to my 3pt lift?
    So... can anyone explain the reason for the tranny return line? Can I block it off? Is there some sort of check valve in-line that gives power to the hitch? Thanks in advance - I apperciate it. DH
  2. #2
    Gold Member Oldtractorfixer's Avatar
    Join Date
    Mar 2012
    Posts
    389
    Oregon City, Oregon
    several
    Default Re: FEL Control Question
    Not sure of your specific tractor but you have an open circuit system. Pressure goes through the FEL valve and if not used goes on to the next item in line, maybe the 3pt. Therefore the two lines you mention are pressure in and pressure out. Often they go to a place on the other end where a line was disconnected and redirected to the FEL then back to the original line. The dump to the top of the transmission is return like when you lower the bucket and the oil (not under hyd pressure) has to return to the reservoir. So fluid should not be freely flowing back thorugh the return. If it is no pressure is going to the 3pt. It sounds like it is plumbed incorrectly. Seems like the left one should be a right one. If it is plumbed correctly and you blocked the return you wouldn't be able to lower the FEL. I hope this helps.
  3. #3
    New Member
    Join Date
    Jan 2013
    Posts
    10
    New castle, CO
    Kubota L245DT
    Thanks for the fast reply... your answer does help.
    So in regards to testing could I disconnect the two returning lines (currently on right side), and crank the engine...if fluid comes out of one, that's my powerbeyond and need to go back to the block. If I actuate my buck drop, I should see fluid come out of the other line and that needs to go to the return on the tranny....?
  4. #4
    Join Date
    Mar 2012
    Posts
    389
    Oregon City, Oregon
    several
    It likely wouldn't come out either. One to trans return one to 3pt. I would connect the two that don't go back to the trans to the right. That should make the 3pt work but the FEL might not. If not reverse those two lines. Be sure you mark them so you can get back where you started if you need to.
  5. #5
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,387
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    If I may jump in here Oldtractorfixer, if he does like he just said oil well come out the powerbeyond port but should not come out the tank port until when one of the levers is move. If it comes out both port when turning over engine then he has no powerbeyond fitting. When checking with both ports open he might put something over the port that oil is coming out and see if it moves to the other hole. Shouldn't be any psi there to mount to anything. His picture doesn't look like it has a powerbeyond fitting, but it could just be a pipe plug inside the valve.
  6. #6
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    First, from one Colorado member to a new Colorado member...welcome to TBN.
    Second, I'm of little help in diagnosing the problem you're having; but I'm going to assume you're new to tractors and hydraulics, and I want to extend a piece of safety advice. Be careful around high pressure hydraulic fluid as the last thing you want is a hydraulic-fluid-injection-injury. From the pictures I've seen of these injuries; the term "nasty" is an understatement. Use a piece of cardboard to check for leaks at fittings. I use a piece of drywall shim cardboard. Avoid the temptation to use your fingers to check for leaks like you might do with your house plumbing. I have to keep reminding myself of that when I work on my hydraulic system.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  7. #7
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Quote Originally Posted by dhostetler View Post
    You could use air to determine the ports.
    You are correct in your assumption, but hyd fluid will get messy.
    PB is usually in the center of one end of the valve, and might have an extra fitting in the port.
    If you put a gage in the IN port of the valve, you can use it to trouble shoot and monitor the hyd system.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  8. #8
    New Member
    Join Date
    Jan 2013
    Posts
    10
    New castle, CO
    Kubota L245DT
    Thanks for all the help and warm welcome. I might give air a try - that's a good idea. The valve is off the tractor and clean from tearing it apart yesterday. From what I'm hearing, PB should have fluid acces once there's fluid at the 'in' port.
    I am new t tractors and hydraulics and apperciate any safety warnings. I just want to make sure I'm not missing something obvious due to my green status. LeeJohn mentioned a PB fitting. The right angle fitting on all the hoses are the same. Does the PB connection has special valving?
  9. #9
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    There are two different PB fittings.
    Some valves have a hex screw that screws inside a port,. and the other PB adapter is a fitting like this.
    Surplus Center - BRAND POWER BEYOND KIT
    Surplus Center - P-BEYOND & CLOSED CENTER PLUG 8 GPM MB VALVES
    No special valving, it is a fitting that separates the return flow and the PB flow.
    Show a pic of what you think is the PB port.
    J.J.
    Git er done.
  10. #10
    New Member
    Join Date
    Jan 2013
    Posts
    10
    New castle, CO
    Kubota L245DT
    In the first post pictur, it would be the top horizontal valve on the right. Let me know if you need a close up of the guts, or inside.
    I just blew air threw the the control. All three valves have access to each other's fluid - unless some one thinks there's an easy fix, i'm thinking new controller because something is wrong (like the application) with mine.
Similar Threads
  1. Rear 3pt only rises with FEL....also FEL control question...
    By Buckgnarly in forum Kioti Owning/Operating
    Last Post: 06-21-2012, 12:03 PM
  2. FEL 4 in 1 control
    By spo307 in forum Hydraulics
    Last Post: 12-18-2009, 05:03 AM
  3. B7610 Question about FEL Control
    By Koz in forum Kubota Owning/Operating
    Last Post: 09-09-2006, 07:56 PM
  4. How Can I Tell a 3-way From a 4-Way FEL Control
    By boustany in forum Kubota Owning/Operating
    Last Post: 10-04-2004, 11:32 AM
  5. FEL control valve question
    By Makers_Mark in forum Owning/Operating
    Last Post: 02-20-2003, 03:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
