Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: JD 830 3Cyl. Power Steering Quits when u clutch the PTO Supply Bypass Valve?????
    Quote Originally Posted by RottenGround View Post
    yes i think it is called supply bypass valve opens due to negative pressure i think it is actually the outlet line off of the tranny pump
    There is also a inlet check valve just off the trans pump to the main pump. The trans filter has bypass valve, it's called a Fiter Relief valve.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  2. #12
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    1974 JD 830, 1946 JD Model A
    thanks for the info is it located inside the tractor or is it external? Thanks for the info on the load control too.
  3. #13
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    http://jdpc.deere.com/pimages/RWP2/R..._UN01JAN94.gif
    I think number 10 is the line and the kicker off of the side is the supply bypass valve What do u think??
  4. #14
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    Key 10 is the output line from the tranmission pump. The branch by Key 11 is going to the trans filter. Not sure if "kicker" goes to surge relief, but it might.
    In attached picture Keys 22-27 are the filter relief/bypass valve.
    I think keys 14-17 are the surge relief valve.
    Both can be accessed from out side the tractor, no splitting required.
    Attached Thumbnails Attached Thumbnails JD 830 3Cyl.  Power Steering Quits when u clutch the PTO Supply Bypass Valve?????????-830filerreliefvalve-gif
  5. #15
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    i tore mine apart over the weekend number 10 like u said is the output from the tranny pump the kicker just hangs there right above the bottom of the sump it just pulls from right there and it has a ball valve that opens during suction from the front mounted pump mine was stuck shut
Similar Threads
  1. Ford 3910 Power Steering Fluid Supply Line Leaking
    By BBlocker in forum Parts/Repairs
    Last Post: 08-06-2011, 01:50 PM
  2. Power Steering Hydraulic issues after clutch repair
    By MichKubota in forum Kubota Owning/Operating
    Last Post: 12-08-2010, 11:52 AM
  3. Replies: 2
    Last Post: 11-21-2009, 09:58 PM
  4. pto clutch support stand 4000 3cyl
    By mattman in forum New Holland Owning/Operating
    Last Post: 08-31-2008, 12:47 AM
  5. Replies: 8
    Last Post: 07-05-2007, 02:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
