Results 1 to 8 of 8
02-03-2013, 09:40 PM #1Advertiser
- Join Date
- Oct 2012
- Posts
- 4
- Location
- Ontario, CA
- Tractor
- None
YZOUTLET | BEST DEALS ON HYDRAULIC CYLINDERS - TIE ROD, TUBE CROSS, CLEVIS & MORE
Feel free to contact us anytime for the best prices on hydraulic cylinders from tie rod to clevis to tube cross! We also offer log splitter valves, hydraulic gear pumps, replacement seal kits and custom forged or casted parts for your tractor and more!
Cheers,
YZOUTLET
yzoutlet@yahoo.com
YZOUTLET - | Hydraulic Cylinders, Gear Pumps, Logs-Splitter Valves & More!Last edited by YZOUTLET; 02-04-2013 at 09:19 PM.
02-04-2013, 07:53 AM #2Advertiser
- Join Date
- Oct 2012
- Posts
- 4
- Location
- Ontario, CA
- Tractor
- None
Re: YZOUTLET | BEST DEALS ON HYDRAULIC CYLIDNER - TIE ROD, TUBE CROSS, CLEVIS & MORE
Check out our Deal of the Month:
Double Acting Hydraulic Tie Rod Cylinder - $99.99
Double Acting Hydraulic Tie Rod Cylinder 4" Bore x 24" Stroke - YZOUTLET
Cheers,
YZOUTLET
02-04-2013, 10:55 AM #3Veteran Member
- Join Date
- Aug 2010
- Posts
- 2,041
- Location
- South West MI
- Tractor
- John Deere 2030, John Deere 6415
Can I specify #8SAE ports instead of 1/2NPT? Tie rod clevis cylinder 3 1/2" bore
John Deere 2030 JD 245SL Loader
John Deere 6415 mfwd JD 640SL Loader
02-04-2013, 08:57 PM #4Advertiser
- Join Date
- Oct 2012
- Posts
- 4
- Location
- Ontario, CA
- Tractor
- None
Hi Zebrafive,
All of our cylinders are 1/2 NPT as of now, I am sorry to inform you but for us to custom make #SAE ports instead of 1/2NPT we would require a minimum order of 50 units. We are however considering carrying #SAE port cylinders in the future.
Please let me know if you have further questions.
Cheers,
YZOUTLET
02-04-2013, 09:36 PM #5Veteran Member
- Join Date
- Aug 2010
- Posts
- 2,041
- Location
- South West MI
- Tractor
02-06-2013, 07:36 PM #6Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,877
- Location
- 4000\' mountains of Southern California
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Zebrafive, do you have to have a tie rod cylinder? Check on a welded clevis cylinder and I am pretty sure that it will be a #8 SAE ORB fitting.
02-08-2013, 08:51 AM #7
02-26-2013, 05:15 PM #8New Member
- Join Date
- Dec 2008
- Posts
- 9
Similar Threads
GC2310TLB FRONT BALL JOINT & TIE ROD
By newmexico in forum Massey Ferguson Owning/OperatingReplies: 6Last Post: 12-03-2012, 06:06 AM -
Track rod assembly (tie rod end)
By kevin3251 in forum New Holland Owning/OperatingReplies: 0Last Post: 12-10-2011, 06:32 PM -
Cylinder question - Tie Rod v Cross Tube
By woodlandfarms in forum HydraulicsReplies: 11Last Post: 03-21-2010, 11:15 PM -
Tie rod hydraulic cylinders?
By Ron25 in forum Build-It YourselfReplies: 3Last Post: 07-19-2006, 07:26 AM -
By Ron25 in forum HydraulicsReplies: 3Last Post: 07-19-2006, 07:26 AM
. If you ever start carrying SAE port cylinders, Post again. I prefer SAE to NPT. I think others do to.
