Results 1 to 4 of 4
02-05-2013, 02:57 PM #1New Member
- Join Date
- Mar 2009
- Posts
- 5
Please help me identify this control valve shaft
I have lost the control valve shaft from my electric-hydraulic log splitter. It is a chinese manufactured splitter that was sold in UK/Ireland by Wolfcraft through the Aldi chain of stores. I can't get the part, and Wolfcraft have gone out of business.
I am posting here on the off-chance that the shaft was used in some other equipment and may be available as a spare. I would also be grateful for any advice as to other forums that might have a greater chance of making contact with other 'experts' who might be able to help me. Please see the attached photo for details.
Hydraulic control valve spool photo:
Dimensions:
The overall length of the item is 85mm. Component E is a sliding collar.
A Spring
B Main shaft diameter is 9mm.
C O- ring
D D Shaft ground down to 7mm.
E Collar is 13mm long and slides on shaft that is 5mm.
Thanks in advance.
02-05-2013, 04:49 PM #2Veteran Member
- Join Date
- Sep 2007
- Posts
- 1,384
- Location
- Doniphan, Mo.
- Tractor
- Kubota L4240, B7800 & BX2660
Re: Please help me identify this control valve shaft
The best thing is just buy a new valve. The spools are honed to match the bore with only a few .0000 The better the fit, the better the valve and more $$$. I think the new valve only cost around $80.00 and with all the calling and messing around you might just be at $80.00.
02-05-2013, 04:59 PM #3Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,480
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
They usually don't make replacement spools.
This log splitter valve is only $65.
Surplus Center - 1 SPOOL 25 GPM LOG SPLITTER VALVE W/AUTO DETENTJ.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
02-07-2013, 10:27 PM #4Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
In the next week or so i'll be putting up a classifieds add for a use log splitter valve that has a detent with a hydraulic kick out on one side/ spring centered on the other. Pm me if you might be interested.
Similar Threads
Can anyone identify this FEL hydraulic control valve?
By mungus in forum HydraulicsReplies: 12Last Post: 08-25-2012, 08:27 PM -
Can You Identify this Valve?
By cycle_gator in forum HydraulicsReplies: 8Last Post: 05-09-2010, 06:47 PM -
help to identify adjustment shaft on YM2310D
By BruceT in forum YanmarReplies: 3Last Post: 11-17-2005, 10:21 PM -
Help identify a PTO shaft
By ChuckT in forum Parts/RepairsReplies: 8Last Post: 06-18-2005, 08:10 PM -
Can anyone help identify this control?
By CVHoss in forum John Deere Owning/OperatingReplies: 7Last Post: 09-19-2001, 09:37 AM
