JOHN DEERE 4300 HAS LOW HYDRAULIC PRESSURE???
   / JOHN DEERE 4300 HAS LOW HYDRAULIC PRESSURE??? #1
dlrfarms
Western,Md.
IH 244,JD4300, 2-JD 4040s,JD2020,JD1020,8N Ford,990 David Brown,3JD318s
John Deere has 1100 psi on rear scv. Replaced the pump after screwing in relief valve and getting no results? Any ideas?
   / JOHN DEERE 4300 HAS LOW HYDRAULIC PRESSURE??? #2
Welcome to TBN!
Can you please describe exactly how you tested the pressure?
Is the return screen clean?
Turned out to be a stuck psi relief valve. ok now. tested psi at back remote with dead end psi. thanks
