Which power steering asst. kit to buy for Ford 3000 WITH loader
   / Which power steering asst. kit to buy for Ford 3000 WITH loader #1
jacobgoggins
Transylvania, Romania
Ford 3000, Kobota 3600
I have been searching for a power steering kit to buy to help me steer my Ford 3000. My tractor has a front loader. In my searching most kits that I find state " not recommended for tractor with loader". Any help in which power steering kit I can use with the loader would be much appreciated.
Thanks in advance :)
   / Which power steering asst. kit to buy for Ford 3000 WITH loader #2
There is only one kit that I am aware of, it is just available from many, many sources. The reason it is not recommended for use with loaders is that you may or may not have clearance issues. What loader do you have?
Thanks J.J. for the links.....
Rick
A picture is worth a thousand words.....looks like it is made by Same.....
Is the clearance problem at the Hydraulic Cylinder Mounting Plate to transmission housing and the hydraulic cylinder itself?
   / Which power steering asst. kit to buy for Ford 3000 WITH loader #5
Looks like J_J sent 3 links to the same kit offered by diifferent sellers. Seems like there will be a conflict between the cylinder and LH loader mount.
yeah....it is hard to say with out the cylinder in hand. Surely I would have to modify the cylinder mounting plate at the transmission housing.
Thank you for your opinion and information.
God Bless:)
   / Which power steering asst. kit to buy for Ford 3000 WITH loader #7
would anyone happen to know why I cant find a steering cylinder rebuild kit for my 92 3930? the ones i find has a disclaimer "will not fit original cylinder only aftermarket"
   / Which power steering asst. kit to buy for Ford 3000 WITH loader #8
Try a New Holland dealer. They sell OEM replacement parts. Know the unit code from your tractor and whether it is 2WD or MFD before calling.
2016 JOHN DEERE 3032E LOT NUMBER 97 (A53084)
2016 JOHN DEERE...
New/Unused 66in Quick Attach Rock Bucket (A51573)
New/Unused 66in...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
New Long Forks (A53002)
New Long Forks...
