Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
  1. #1
    New Member
    Join Date
    Mar 2013
    Posts
    12
    Missouri
    1050 John Deere
    Default 1050 John Deere. Question about 3 point hitch and hydraulics
    I just bought a 1050 JD and the 3 point hitch won't go up. It looks like I need to put in some hydraulic fluid. I'm new to tractors. my question is, is there a certain procedure I need to go by when adding it? Such as does the tractor need to be running when I fill it, etc. I don't want to screw it up. I'd appreciate any response. Thank you very much.
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: 1050 John Deere. Question about 3 point hitch and hydraulics
    Fill to the proper level, and check again when warm.
    Get the proper fluid for your climate.
    Where is Bucyrus?
    Does any of the other hyd work?
    Hydraulics:
    Type: open center
    Capacity: 6.875 gal [26.0 L]
    Pump flow: 7.5 gpm [28.4 lpm]
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    New Member
    Join Date
    Mar 2013
    Posts
    12
    Missouri
    1050 John Deere
    After adding the hydraulic fluid I adjusted this brown valve that appears to be some kind of bleeder or something. When you open it up it looks similar to a tire stem of sorts. I heard a noise after opening the valve, like a groaning sound. The 3 point will work slowly at high rpm. It's working but working very slow. The fluid is white. When not running the fluid is up to the highest mark. before, when not running the fluid was not showing. The pictures show the brown thing i'm talking about which is put on top of this extra hydraulic manifold, after market to service 3 plug remotes.
    This is my first tractor and I'm only 21. I don't know if this bleeder valve has anything to do with why it started working or if because i added the hydraulic fluid, and either way it's still working very slowly.
    If anybody could give me some help i'd appreciate it. it's very frustrating
    1050 John Deere.  Question about 3 point hitch and hydraulics-dsc03091-jpg1050 John Deere.  Question about 3 point hitch and hydraulics-dsc03092-jpg1050 John Deere.  Question about 3 point hitch and hydraulics-dsc03093-jpg1050 John Deere.  Question about 3 point hitch and hydraulics-dsc03094-jpg1050 John Deere.  Question about 3 point hitch and hydraulics-dsc03095-jpg
  4. #4
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by antisolo View Post
    You have water in the fluid, you need to drain the system and fill.
    Murph
  5. #5
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Seems you have some remote valves on that, you have a owners manual?
    Murph
  6. #6
    New Member
    Join Date
    Mar 2013
    Posts
    12
    Missouri
    1050 John Deere
    I'm waiting for one to come in the mail.
    What could be making it go slow? A plugged filter maybe? Or would it for sure be water mixed with the fluid?
  7. #7
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    I think the valve you opened and shown in the pic is a relief valve for the 3pt.
    The sound you heard was probably the relief valve going off. That is what sets your tractor max operating pressure.
    Get that old fluid out of there and flush the system.
    Check the relief valve pressures.
    Make up a 3000 psi hyd test set like these and you will be able to monitor and trouble shoot the hyd system..
    Attached Thumbnails Attached Thumbnails 1050 John Deere.  Question about 3 point hitch and hydraulics-3000-psi-hyd-test-gage   1050 John Deere.  Question about 3 point hitch and hydraulics-3000-psi-hyd-test-gage
    J.J.
    Git er done.
  8. #8
    New Member
    Join Date
    Mar 2013
    Posts
    12
    Missouri
    1050 John Deere
    Quote Originally Posted by J_J View Post
    how do i do that?
  9. #9
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    You install the hyd gage in the IN port of the first valve.
    Or you could install female QD's where you want to test and plug the gage into the QD.
    J.J.
    Git er done.
  10. #10
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Heyy JJ, am I seeing remote valve set up in his pics?
    Murph
Similar Threads
  1. John Deere 2305 3 point hitch operation question
    By ZettaDeere in forum John Deere Owning/Operating
    Last Post: 09-18-2012, 07:31 AM
  2. John Deere 60 3 point hitch
    By aftonknight in forum Attachments
    Last Post: 09-12-2012, 10:48 PM
  3. john deere 2320 3 point hitch
    By katt68 in forum Owning/Operating
    Last Post: 03-20-2012, 05:13 PM
  4. John Deere model G 3-point hitch
    By JackDWaller in forum John Deere Vintage Tractors
    Last Post: 01-05-2012, 03:29 AM
  5. John Deere 1050 PTO question
    By MarcusWard in forum John Deere Owning/Operating
    Last Post: 03-30-2010, 11:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
