bigdeano
Yarg - Gray,
Sounds like you have it under control. I was thinking last night you need to restrict the down movement too. Will be interesting to hear how it works. Post some pics when you get it drilling.
J-J,
You're right, the pressure takes care of itself, but with so much flow it was trying to accellerate the heavy mast so fast it was developing enough pressure to open the relief. With the much lower flow the pressure should be steady and determined by the weight of the mast.
Mace,
The problem was apparently caused by the cylinder trying to raise the mast in something like a half second. The lack of valve feathering capability seems strange, but maybe that's the way the log splitter valve is made. I've never messed with them. It will be interesting to see what finally fixes it.
J-J,
Mace,
