Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    New Member
    Join Date
    Apr 2012
    Posts
    11
    uk
    885xl
    Default Re: International hydraulic problem
    As I am not a mechanic I never thought of that problem, where do you suggest that I should connect the return too. I take that is ok to use the s/a spool valve as the feed. Would it be. Advise able to use the d/a valve as the feed and return.
  2. #12
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    All three of my hyd pumps return the fluid below the level of the tank.
    So even if you are adding the return fluid to the filler cap, the opening of the tube should be below the level of the tank fluid. You can also make the return a dip stick level.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #13
    Join Date
    Dec 2011
    Posts
    226
    "Murray"
    Supplying avalve bank from another bank is not ideal also??
    I will post some documents later, the correct way to supply loader from the (HPCO) high pressure carry over, which fits on the end of the valve bank, ( may be there already) and the return goes to the bottom of the transmission case, a large 1 5/16 AF plug under the r/ hand axle carrier.
    This reduces noise and heating and ensures longer pump life by reducing cavitation and turbulence in the hydraulic system.
  4. #14
    Join Date
    Dec 2011
    Posts
    226
    Murray !!
    These att's show how to connect the loader using the HPCO and where to return oil !!
    Attached Thumbnails Attached Thumbnails International hydraulic problem-74-84-85-series-nao   International hydraulic problem-74-84series-hpco-connectors-jpg   International hydraulic problem-74-84-85-95-32-a
  5. #15
    New Member
    Join Date
    Apr 2012
    Posts
    11
    uk
    885xl
    Quote Originally Posted by cyrush View Post
    Murray !!
    Thanks a lot for your att's they have solved my problem as where to connect the flow and return, much appreciated my friend. Will have to adjust the connections asap. If only I can get the flow problem sorted now.
  6. #16
    Join Date
    Dec 2011
    Posts
    226
    Thats o/k, have you checked the bolts yet ??
    Do you have a service manual?? I sell PDF copies of the genuine IH manuals which i supply as a download. They can be stored and viewed on the computer and you can print off the odd page as you need it. If you needfurther info, please send me a PM with your e mail address.
  7. #17
    New Member
    Join Date
    Apr 2012
    Posts
    11
    uk
    885xl
    I have not checked the bolts yet as I am attending to the sheep lambing, early mornings-late nights. No I do not have a service manual yet, send me the details please to murrayp39@yahoo.co.uk
    Looked at your guides for the hose connections which I think will help me to connect the hoses the correct way.
    Many thanks for your help
  8. #18
    Join Date
    Dec 2011
    Posts
    226
    Yes i understand the time of year only too well, been there, done that!!., spent my first 20 odd years on family farm in Cumbria, dairy, pigs, sheep, beef & poultry!!!
    Get back to us when u can and we can progress the diagnostics till we find the cause??
  9. #19
    New Member
    Join Date
    Feb 2015
    Posts
    8
    San Jose
    IH 784
    The High pressure carry over (HPCO) is the correct method to supply oil to a loader or other valves
    mounted on the tractor!!
    How many spools are fitted to tractor 1or 2 ?? Question?? If loader is supplied from the SA valve, where is the return piped to ??
    However i suspect an oil leak on the draft control valve to lift cylinder mounting allowing oil loss from the hitch when the hitch is in any position but fully up!!
    Under the seat is an inspection plate in the cab deck, remove this, then you will see the heads of 4 large bolts, just put a spanner on these and see if they are tight!!
    You seem to be the guy to contact regarding HPCO and IH 784 tractors. I installed the HPCO end plate on my S/A valve and routed to an external valve. The tank line is routed to the transmission plugged as commonly suggested. Also, there's a power beyond port on this external valve which is currently dead ended. I will tie this to my loader valve (a second external valve). The purpose of the first external valve is to add a pairs of auxilliary outlets. After a test run, I have flow coming from the HPCO (after cracking a line), but no high pressure. 3 point, steering work fine. I don't quite understand the HPCO. Normally this is plugged off. So if adding a HPCO end plate is same as adding an end plate with a port, why doesn't the tractor pump dump over relief valve when the HPCO is plugged or capped off (or in configuration with original end plate with no port)?
Similar Threads
  1. 3444 International Backhoe Hydraulic Problem
    By Bryce0623 in forum Hydraulics
    Last Post: 11-21-2013, 05:56 PM
  2. international 500e problem
    By international500c in forum Parts/Repairs
    Last Post: 04-13-2012, 10:56 PM
  3. International 2400 problem
    By alchemy in forum All Other Brands
    Last Post: 04-13-2012, 02:55 PM
  4. My international has a hydraulic problem
    By tman0987 in forum Hydraulics
    Last Post: 02-10-2009, 04:57 PM
  5. My international 3514 has a hydraulic problem
    By tman0987 in forum Parts/Repairs
    Last Post: 02-10-2009, 04:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
