gaspumpcity
Im looking for info on my leaking 3 spool valve that controls lift,boom and float and rear down pressure.This is a Russian tractor and bucket also.I removed the dog house covering the spool valve and found my oil leaking out the control valves.Can seals be replaced in the tractor or is it best to just remove it and make repairs on the bench? There are a hand full of 10mm bolts holding the cover over the control valves now if I remove these bolts will the control valves just slide out so I can reseal them ?
