Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Join Date
    Apr 2006
    Posts
    2,164
    western NC
    Ventrac, Steiner
    Default Hyd motor ID
    I have a rexroth hyd motor I need some more info on. There are 3 numbers on the tag attached to this motor.
    codice#7.003210001
    serial# 1301569 028
    data# w2311
    Info I need is cuin displacment, max flow, max psi, and max rpms.
    I know this motor will run 3150rpms at 2150psi and 18.5gpm. This suggests a 1.3cuin motor. I have been told, but havent be able to verify, that this motor would run at 4800rpms at around 30gpm which are the numbers I am shooting for. I just hate to go thru the build process and findout my info is wrong at the end of the project. Any help would be appreciated.
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Hyd motor ID
    30 GPM would run the 1.3 cu in motor at 5331 rpm.
    Where did you get the pressure limit from?
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Check your motor out with some comparative data.
    Bosch Rexroth Mobile Hydraulics
    PSI BAR Converter
    Cubic Centimeters To Cubic Inches (cm3 to in3)
    That is not a lot of torque.
    What are you building?
    Attached Thumbnails Attached Thumbnails Hyd motor ID-rex-png   Hyd motor ID-rex1-png
    J.J.
    Git er done.
  4. #4
    Join Date
    Apr 2006
    Posts
    2,164
    western NC
    Ventrac, Steiner
    JJ, this motor is used on a vibrating assembly. The numbers posted came from the schmatics for the equipment. I am wanting to use the motor to run a hydraulic chainsaw. I dont believe the numbers I posted are the lmits for this motor, just what it is speced for the particular assembly it came off of. I am trying to find out what those limits really are.
  5. #5
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,757
    Northern, IL
    Branson 2400H, JD X540
    Quote Originally Posted by muddstopper View Post
    codice#7.003210001
    serial# 1301569 028
    data# w2311
    These do not look like any Rexroth part numbers that I have ever seen. Suspect these are the OEM numbers from the machine you took this motor off of.
    I presume this is a gear motor with that small of displacement.
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD X540
  6. #6
    Join Date
    Apr 2006
    Posts
    2,164
    western NC
    Ventrac, Steiner
    I am suspect as to displacment. This motor is a bmount and weighs probably 25lbs, with #12jic ports and a casedrain. The numbers came off a tag attached to motor. It is, or should be, a rexroth, but it is a special application motor. I havent been able to find anything using those numbers either. I suspect the equipment manufacturer could have attached their own tag to the motor, but those folks wont tell me anything about the motor. Sell me a new one they will, but I guess they are afraid someone might try to find a cheaper replacement instead of buying one from them if they give out to much information.
  7. #7
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,757
    Northern, IL
    Can you post a picture of the motor. Some times a picture is worth 100 posts. This may be one of the older Rexroth gear motors that they sold to some one. I want to say Haldex Barnes but not sure. I think they were made in either North or South Carolina. Just looking in one of my old books and the 1.28 cubic inch that had an SAE B mount & had #12 SAE ports. Those models all stated with PF in the model code and were good to 3600 PSI.
    JD X540
  8. #8
    Join Date
    Apr 2006
    Posts
    2,164
    western NC
    Ventrac, Steiner
    This pump is 5 1/4in wide and 7 1/2in long
    Attached Thumbnails Attached Thumbnails Hyd motor ID-0315131400-jpg   Hyd motor ID-0315131401-jpg   Hyd motor ID-0310131321a-jpg
  9. #9
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,757
    Northern, IL
    That looks like an axial piston motor. Possibly A10F* series. If you remove the SAE plug show in the top middle of the motor do you see a rotating group consisting of the cylinder and some pistons. If you remove the work port plugs you should see some kidney shaped ports that feed the pistons.
    Do a google search for RA 91172. This should be the data sheet for the A10FM motors.
    JD X540
  10. #10
    Join Date
    Apr 2006
    Posts
    2,164
    western NC
    Ventrac, Steiner
    I think you are on to something, the a10fm 23-28 looks pretty close to what I have. I still havent figured out how to match the numbers up to cuin displacment
    looking at the serial number serial# 1301569 028, and assuming the last 3 numbers also represent the displacment, then this would make this a 1.73cuin motor. My 30gpm intended fluid flow would produce only 4006 rpms. My intended pressure was only 1500psi and would yield 413inlbs and about 31hp. Not exactly what I am looking for.Do these numbers sound about right to you
Similar Threads
  1. What happens when you choke a HYD motor?
    By tpulley in forum Hydraulics
    Last Post: 01-25-2012, 03:11 PM
  2. Need help picking hyd. motor
    By afish in forum Hydraulics
    Last Post: 09-15-2011, 02:21 AM
  3. Brush hog hyd motor
    By J_J in forum Power Trac
    Last Post: 03-17-2011, 07:22 PM
  4. Hyd motor & Ram in one circuit; How? Help Please
    By Hows she now in forum Hydraulics
    Last Post: 11-22-2009, 06:17 PM
  5. HYD.motor
    By seedman4 in forum Attachments
    Last Post: 07-16-2008, 10:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
