Results 21 to 27 of 27
03-20-2013, 07:08 PM #21Bronze Member
- Join Date
- Jan 2012
- Posts
- 68
- Location
- Mountaindale, Oregon
- Tractor
- Allis Chalmers ACD19, ACG; Kubota BX2200 FEL, B2710 FEL, L355SS FEL; Cat D47U, Ford 4600SU FEL
Re: New Member - Please check my rear remote install.
JJ
Maybe??
The last post was my recollection of what I had done but after looking closely I find it to be way different. Evidently my Alzheimers has progressed beyond expectations.
Loader valve IN port hose from Engine block (there are two ports on this little aluminum looking block (assuming this is pressure and return ports?)
PB port hose on loader valve to IN of remote valve
Remote valve OUT and Loader valve OUT to Tee and plumbed to fitting on side of Hydrostat?
PB port on remote valve to Engine block (return? fluid)
Dennis
03-20-2013 07:08 PM # ADS
03-20-2013, 07:24 PM #22New Member
- Join Date
- Feb 2013
- Posts
- 9
- Location
- Daniels WV
- Tractor
- NH TC-40da w/ 16L
I am not trying to confuse you, however i can understand if my confusion is rubbing off. The prince valve in the picture you attached is the OEM FEL valve.
I am glad to hear you say that is a relief valve port, as i could not figure out what it was. I had thought it might be a pb port.
I am installing a separate 3 stack valve for use with rear remotes, and i have not installed any of the hoses for it. It is merely mounted to the tractor awaiting hookup.
Below the pictures will show the changes I have made since I read some of your other post. I plan on replacing the black cover with the aluminum block. I reinstalled the PB port and will connect a hose to it and send it to the aluminum hyd. block pictured. The "pressure in" I plan on also hooking up at the aluminum hyd block (center most connection) and connecting to the "in" port of the stack valve. The "out" as I now understand needs to return to tank. So i was thinking instead of cutting the piping on my tractor i would replace the yellow fill cap with a sae 12 oring to 1/2 Jic fitting.
Please correct me if I am wrong in my assumptions or plans.
Andy
03-20-2013, 07:37 PM #23Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,656
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
What is the purpose of the hyd block with the two ports and fittings.
If I were to add the blue remote valve, I would find the line where the PB line goes into the side of the tractor for the 3pt, and insert the remote valve in series with the PB flow.
The blue valve needs a PB adapter to feed the 3pt IN port on the side of the tractor.
Do you not have a hyd block where the pump flow goes into it and the output goes to the loader valve? First post, third picture.
It also has the tractor relief on it.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
03-20-2013, 10:38 PM #24Platinum Member
- Join Date
- Dec 2006
- Posts
- 652
- Location
- Columbus, Georgia
- Tractor
- Kuborta B2400, L2900, L4330; Caterpillar D3B, John Deere 455D
Andy,
you are almost done. The Woods hydraulic block actually lets you insert your PRINCE valve into the high pressure circuit just before the TPH; all that is left is to connect the out/tank port of the PRINCE valve into the tank/reservoir. You indicate that you might just dump the low pressure fluid from Prince valve into the tank filler neck. There is at least one disadvantage: the fluid will discharge into open space which will cause aeration. Most systems have the discharge fluid entering underneath the surface of the fluid to prevent that. I believe it will worth the effort to identify all the tank lines and determine which one is most easily teed into. Tee connectors are available that are a little like compression fittings for copper tubing, but designed for steel pipe at hydraulic pressures; unlike the copper fittings, these ferrules have sharp edges that bite into the pipe. I use them often and although I always think them a little shakey, they have always worked. Several sponsors have them and they are not expensive. You just cut out a short section of pipe, tighten the collar nuts, and then connect the out hose from the Prince valve to the third port of the tee.
We look forward to pictures.
03-24-2013, 02:54 PM #25New Member
- Join Date
- Feb 2013
- Posts
- 9
- Location
- Daniels WV
- Tractor
- NH TC-40da w/ 16L
Thanks Farmerford, thought I was in left field there for a while. I now understand the importance of returning the fluid to tank below the fluid level. I wanted to avoid cutting the oem pipes but looks like thats what I need to do. So, I have identified the #8 port on the diagram below as the "path to the reservoir". The picture below shows the bottom pipe that I will cut. I will cut the pipe and install a tee. Am I correct that these are called flareless bite type tees?
J_J I had purchased the two port block thinking that if it was sufficient for a BH attachment , then it would be good enough for a my remotes. I now think that it is as long as I use a third "out" port. If not I would run the risk of blowing out the low pressure port if/when 3pt hitch exceeded 500PSI.
I understand now how you where explaining to use the Manifold Block Power Beyond. I do want to limit the amount of alteration to original equipment and I have already committed a fair amount of money to using the rear remote block. If I were not so far along, your method would probably be my preferred method. Thanks for the info and guidance.
I will definitely post pictures when I get things hooked up.
03-25-2013, 09:37 AM #26Platinum Member
- Join Date
- Dec 2006
- Posts
- 652
- Location
- Columbus, Georgia
- Tractor
Andy:
Looks like you have it under control. Yes, the fittings are called among other things flareless bite type. The only caution I have is to cut the metal line in a straight section so that there is adequate straight tubing to enter each end of the tee fitting and if possible cut in the middle of the line rather than at one end near a fitting since if the line is under strain because it does not line up exactly with the fixed ports on each end it is easeir to bend it a little to line it up with the tee.
We look forward to pictures of the finished project.
03-29-2013, 08:16 PM #27New Member
- Join Date
- Feb 2013
- Posts
- 9
- Location
- Daniels WV
- Tractor
- NH TC-40da w/ 16L
Similar Threads
1532 Rear Remote Install W/ Pics
By kabong57 in forum Massey Ferguson Owning/OperatingReplies: 16Last Post: 01-26-2013, 03:20 AM -
Rear Remote Install
By shibaura_4043 in forum HydraulicsReplies: 5Last Post: 08-21-2012, 05:33 PM -
Rear Remote Install
By markwillcott in forum John Deere Owning/OperatingReplies: 8Last Post: 04-08-2010, 05:44 PM -
CK20 Rear Remote Install
By KAB in forum Kioti Owning/OperatingReplies: 3Last Post: 03-11-2007, 09:24 PM -
Rear Remote install for TC18
By guyw in forum New Holland Owning/OperatingReplies: 3Last Post: 02-11-2006, 07:27 PM
