Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    hr3
    hr3 is offline
    Join Date
    Oct 2008
    Posts
    860
    Mid. Coast Maine
    7610 hst
    Default Re: Hydraulic cylinder sizing ??
    Ok here is the cylinder I have found,, What do you think,,,, I'm going to look for a valve to run 2 of them next... ITR-2014 - Tie-Rod Cylinder - 2" X 14" by International Hydraulics
  2. #12
    hr3
    hr3 is offline
    Join Date
    Oct 2008
    Posts
    860
    Mid. Coast Maine
    7610 hst
    I'll be going with the valve that JJ recommended in his last post.. Now I also have to order the Power Beyond adapter ?? Right?? and I don't want the 2 cylinders I am adding to go too fast so do I need 2 flow controller's ???
  3. #13
    J_J
    J_J is offline
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,462
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Install the valve with PB first.
    Yes, you will need the PB adapter.
    Your pump volume and lever management will dictate how much fluid is going to the cyl's.
    If they are still to fast, then install a needle valve in the cyl line that you want to slow down.
    Small cyl hoses will slow the volume somewhat.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #14
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,462
    JACKSONVILLE, FL
    A 2 in cyl with a 16 in stroke will be very fast with a 13 GPM pump.
    Like bam. it throws the log at you.
    A 3 in cyl will be half as fast.
    Attached Thumbnails Attached Thumbnails Hydraulic cylinder sizing ??-2-cyl.png   Hydraulic cylinder sizing ??-3-cyl.png
    J.J.
    Git er done.
  5. #15
    Join Date
    Mar 2007
    Posts
    1,005
    Midwest
    Iseki TA 247. Husqvarna, Cub.Polaris ATV's
    With JJ's help, I also built a lift arm for my splitter. I used a 3.5" x 8" cyll. It performed perfectly. Not too fast not too slow. Today it lifted a stump that I could barely roll on to it. No problem. Didn't need an extra leg to off set the weight. it works awesome. My back feels great and I no longer have to toill away using my loader to lift heavy logs. Wish I would have done it 20 years ago.
  6. #16
    hr3
    hr3 is offline
    Join Date
    Oct 2008
    Posts
    860
    Mid. Coast Maine
    7610 hst
    Still waiting for my stuff to show up.. Today I worked on the stabilizer leg for the splitter and came up with a simple cantilever ratchet latch so I don't think I'll need the second cylinder for the table lift I'm adding.. I was wondering if the valve I ordered can be used for the splitter valve and lift table valve ?? I'll save the valve that is on it now for another project,, Surplus Center - 2 SPOOL 14 GPM PRINCE WVS21BB5C1 DA VALVE
  7. #17
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,462
    JACKSONVILLE, FL
    Yes, you can use that valve as a log splitter valve. Except
    It is a spring centered, when you let go the lever, it springs back to center.
    You will have to hold the lever for extend and retract.
    Might get a little tedious, when you could be getting the next log ready.
    J.J.
    Git er done.
  8. #18
    hr3
    hr3 is offline
    Join Date
    Oct 2008
    Posts
    860
    Mid. Coast Maine
    7610 hst
    Is this what I need to hold the lever so it will return by its self ??? Surplus Center - DETENT KIT PRINCE 14 GPM MONOBLOCK VALVE
  9. #19
    J_J
    J_J is offline
    Join Date
    Sep 2003
    Posts
    13,462
    JACKSONVILLE, FL
    No.
    Detent means that the lever will stay in a certain position, and fluid will continue to flow, or in a detent float position, the fluid is allowed to move in relation to the ground contour.
    Detent could be a couple of balls in a groove holding the spool in position, pressure detent, or friction detent.
    A log splitter valve has a detent in retract. You push the lever to retract, and the lever stays in detent until a certain pressure is reached, and then the lever returns to neutral.
    Some valves could also have three position detent, where the lever can lock in three position.
    The kit you show is for a spring center valve to convert it for a three position detent operation.
    The three position detent will lock the lever in any of the three position.
    If the pump is pumping, a detent lever will allow the fluid to flow through a work port to a motor. You would not want to detent a cyl, as when tthe cyl is fully extended or retracted, the relief would activate.
    What is your intended use of a detent valve?
    The below data is just some of the features that can be added to some valves.
    Pressure Release Detent
    1 Position Detent, Spool "out" Only,
    Spring Center to Neutral
    F**
    2 Position Detent, Spool "in"
    and "out", Spring Center
    to Neutral
    Spool "C" or "E" Only
    G**
    4 Position, Spring Center to
    Neutral, Detent Spool In for
    Float Position
    J.J.
    Git er done.
  10. #20
    hr3
    hr3 is offline
    Join Date
    Oct 2008
    Posts
    860
    Mid. Coast Maine
    7610 hst
    Quote Originally Posted by J_J View Post
    No.
    F**
    to Neutral
    G**
    Float Position
    I would like the detent to hold the return of the cylinder after the log is split.. Should I just get a bungee cord ???
Similar Threads
  1. Sizing a hydraulic motor
    By dlc2cg5 in forum Hydraulics
    Last Post: 11-29-2010, 04:54 PM
  2. Dump Cylinder sizing
    By Steve_Miller in forum Hydraulics
    Last Post: 10-01-2010, 03:24 PM
  3. Hydraulic Pump Sizing
    By MReeb in forum Hydraulics
    Last Post: 04-25-2008, 02:13 PM
  4. hydraulic splitter sizing
    By marks in forum Rural Living
    Last Post: 03-01-2008, 04:37 PM
  5. Sizing a Backhoe Thumb Cylinder
    By Dougster in forum Hydraulics
    Last Post: 08-01-2007, 06:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
