Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Mar 2013
    Posts
    3
    Auburn ,Maine
    Terramite T5C John Deere 455
    Default terraman51
    Hello All, would like to know if there is a small auxiliary pump that would run the power steering of t5c terramite, 250 to 300 psi ?
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: terraman51
    Are you sure the pressure is 250 to 300 psi?
    My Power-Trac uses a pump like this to power the steering and the lift.
    .75 to 1.0 GPM @3000 psi
    250-056 GC GEAR PUMP 0.097 CID DUAL Gear Pumps | Gear Pumps GC Series | Bolt 1/2'' Dia Straight Keyed Shaft x 1 1/2'' Long, Dual Rotation
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    New Member
    Join Date
    Mar 2013
    Posts
    3
    Auburn ,Maine
    well the main pump "eaton" puts out that kind of pressure, but the section of it that runs the power steering is only 300 psi max.
  4. #4
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Does your hyd steering use the charge pump pressure?
    I use an Eaton VSP pump in my Power-Trac, and the charge pump puts out about 350 psi.
    J.J.
    Git er done.
  5. #5
    New Member
    Join Date
    Mar 2013
    Posts
    3
    Auburn ,Maine
    sorry,I do not know what that is.
  6. #6
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    If you have a variable speed pump, you probably have a charge pump.
    The charge pump is the only low pressure element associated with a variable speed pump that I know of. The charge pump could be internal or external.
    Here is a pic of my charge pump.
    M or red arrow
    Attached Thumbnails Attached Thumbnails terraman51-eaton-vsp-pump-png
    J.J.
    Git er done.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
