Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 47
  1. #1
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    1974 JD 830, 1946 JD Model A
    Default Putting on a loader on a JD 830 1974
    where can i plumb in hydraulics for a front end loader the loader has only two lines im am assuming one is pressure and the other is a return any help please
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Putting on a loader on a JD 830 1974
    You have an open center hyd system, and you need a two spool valve to operate the loader.
    A two spool valve has 4 work ports , each work port will feed a cyl port, A/B work ports will feed say the lift cyl's, and the C/D work ports will feed the cyl cyl. The work ports may be label 1,2,3,4, or A1,B1, A2, B2.
    It will also have IN ,OUT, PB ports.
    The standard loader valve is usually a joystick valve to operate the lift and the curl.
    Here is a valve that will probably work if your loader does not have one.
    Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
    This valve has regen and float.
    You need to find the pump pressure outlet from the tractor and feed the pressure line to the IN port of the loader valve and the valve PB outlet will feed the 3pt, and the OUT port of the valve will go to a tank line.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    hey thanks lot that helps the loader is a MF and was working on a Massey tractor it already has the joystick it b thejust has two hoses that went to the tractor so are they a pressure and return do they go inline or just plumb
    in the pressure and dump the return to the sump thanks
  4. #4
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    Also You said my tractor is open center hyd the loader i think is a MF 255 that was on a MF 235 tractor does it have open center like mine JD 830 so if i can adapt the loader to fit the tractor will the factory MF joystick valve set up work on mine
  5. #5
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Most loader valves are similar, using two spools.
    However some of them only have 6 ports, and others have 7 ports on the valve.
    The seventh port is the PB port which is used to feed fluid to a downstream valve.
    A 6 port valve should have the OUT port go directly to tank, and not feed another valve.
    J.J.
    Git er done.
  6. #6
    Silver Member OldGinTractors's Avatar
    Join Date
    Mar 2012
    Posts
    133
    Dardanelle, AR
    Many Mahindras
    Does your JD 830 have a rear remote? If so you can pump the pressure and return hose to it but will have to tie the remote valve open when operating loader.
  7. #7
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,235
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    This is the way JD plumbed a loader valve on an open center tractor such as yours.
    Attached Thumbnails Attached Thumbnails Putting on a loader on a JD 830 1974-ep12939________un10may05-gif
  8. #8
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    yes the loader that i am looking at just has two hoses coming to the tractor i think i will plumb in right after the pump and dump the other to the resivoir
  9. #9
    Join Date
    Jan 2007
    Posts
    7,235
    Coyote Flats,Tx
    How do you plan to tap into hyd line from pump? You need to be sure relief valve on loader control valve isn't set too high for 830 hyd pressure or damage to hyd pump could result.
  10. #10
    Join Date
    Jan 2013
    Posts
    52
    Ozark, Arkansas
    I have a flex line/hyd hose from the pump to a steel line i was just going to tee into that but im not sure if the loader is open or closed one way would be to tee into pressure if it is a closed sys with it being closed system it would stop at the tee but still be able to go onto the rest of the tractor. If it is an open sys on the loader i would need to put the loader in line from the pump correct?
Similar Threads
  1. Replies: 3
    Last Post: 02-05-2013, 10:35 PM
  2. Loader 1974 Ford 3400- Loader Questions
    By TBigLug in forum New Holland Owning/Operating
    Last Post: 12-31-2011, 07:51 AM
  3. Oil & Fuel 1974/75 830 3 cyl diesel
    By Villengineer in forum John Deere Owning/Operating
    Last Post: 03-04-2007, 08:27 AM
  4. Info needed on old 1974 Deere Loader Backhoe
    By PBinWA in forum Construction Equipment
    Last Post: 05-31-2006, 08:45 PM
  5. putting on loader
    By Anonymous Poster in forum Attachments
    Last Post: 07-23-2001, 05:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
