Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
  1. #11
    Member
    Join Date
    Aug 2009
    Posts
    44
    Caledon, Ontario, Canada
    Kubota B2920, Kioti CK35 HST, MF-205
    Default Re: help hook up for 3 ph forklift
    I think You got it I took a quick connect (female) and was working the spool valve so there is a return flow through that hose but is low pressure it seams (weight of the fork lift pushes the oil) ,I'm afraid that if I put a tee the pressure circulating through the spool will prevent from dumping the oil I think I need to attache to "sump" where there is no pressure now where is that on the tractor ? do I need to run a new line to sump with the quick connect that would be the logical choice, I have a Kioti CK35
  2. #12
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,244
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Before you actually try to plumb the return hose to sump just temporarily stick hose in the hyd filler hole and see if forklift will lower correctly.
  3. #13
    Member
    Join Date
    Aug 2009
    Posts
    44
    Yes it does I just tried it works perfectly, now to find a plug in the sump so I can plumb it
    Paul
  4. #14
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,997
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by Xfaxman View Post
    I looked at your first picture, I think the quick disconnect has to go to the return line to the reservoir (sump). You can put a tee with a matching quick connect, any where in the return line.
    How and where are the in/out hoses connected?
    Quote Originally Posted by wpala View Post
    There is no pressure in the return line past the last valve. What you have on that spool, is a single action valve.
    It looks like there is a power beyond plug in the valve body. Does it have "PB" on it right below the out port? There is something there, just can't read it in the picture.
  5. #15
    Join Date
    Jan 2007
    Posts
    7,244
    Coyote Flats,Tx
    What difference would it make if the spool valve has a power beyond? The hose with the disconnect needs no pressure.
  6. #16
    Join Date
    Feb 2013
    Posts
    7,997
    Meridian, OK
    Quote Originally Posted by Tx Jim View Post
    If it has PB there would be pressure on the out line. If not he might be able to tee into the out line, depending what it is connected to.
  7. #17
    Join Date
    Jan 2007
    Posts
    7,244
    Coyote Flats,Tx
    The hose that the QD is attached to has nothing to do with the bright cap(PB or OC/CC) in this photo as pressure on hose in question is controlled by the spool.
    Attached Thumbnails Attached Thumbnails help hook up for 3 ph forklift-capture-jpg
  8. #18
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Are there any other valves past the valve you show?
    If not, why not just tee into the OUT/return hose.
    If there is another valve downstream, then use the PB port for downstream fluid and then tee into the the OUT/return hose.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  9. #19
    Member
    Join Date
    Aug 2009
    Posts
    44
    Thank You all for the responses I appreciate them, here is what I think I know about all of this,
    I have to turn the float switch on my tractor to run auxiliary hydraulic outlet , the control valve in question has 2 spools one controls a top link simple in and out second one hose is permanently screw on the bottom of the long cylinder that lifts the carriage of the forklift attachment, and the top line I figured is a dump line of the oil but the pressure of that line is not very high depending on the weight of the load on the fork lift, I ave tried to tee 2 return lines in tho back of the tractor no good, there is a pressure circulating in that line that will not allow to dump the oil, my understanding is that if the valves are closed the oil still circulates through the control valves (passing by waiting to be used) I have a spare quick connect female that I have attached to that hose in question and pointed in to my filling tube (where you add hydraulic oil) and was operating the valves and everything worked perfect goes up and down no problem, now I just have to find a place on the valve or tractor where there is a no pressure dump possible and is all good or I can change the piston on that valve to act as a single stage valve which will be hard since I can't find any info on the star hydraulic (maker of this control valve)
    Paul.W
  10. #20
    Join Date
    Sep 2010
    Posts
    66
    Ford 5000
    I have a forklift mast I adapted to my tractor.The raise/lower cylinder is power up,gravity down.When I first hooked to my tractor if I tried to power it down the top seal leaked.So I just put the return hose back to the reservior.I have a level plug and plumbed it to there.You have seemed to have figured this out already.Can you just put a tee where you have it now so it can return and you still have fill access?
Similar Threads
  1. need help with hook ups on john deere 750 to hook up FEL
    By krisbodean85 in forum John Deere Owning/Operating
    Last Post: 04-18-2013, 07:38 AM
  2. 3 Pt Forklift
    By ch47dpilot in forum Build-It Yourself
    Last Post: 04-29-2011, 08:04 PM
  3. Replies: 0
    Last Post: 05-05-2008, 02:23 PM
  4. Forklift
    By BSims66173 in forum Build-It Yourself
    Last Post: 11-22-2002, 10:35 PM
  5. Forklift
    Last Post: 11-19-2002, 09:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
