Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
  1. #1
    Member
    Join Date
    Aug 2009
    Posts
    44
    Caledon, Ontario, Canada
    Kubota B2920, Kioti CK35 HST, MF-205
    Default help hook up for 3 ph forklift
    Hi so I bought this quite old 3 ph forklift attachment and to my surprise it has 3 quick connect houses my tractor has only 2outlets available on the back, the picture follows the first spool controls the top link no questions there the second spool is problem since the ram cylinder on the forklift part has only one connection on the bottom that would make it act as a single port cylinder so my question is what is the second hose with the quick connect for?? how can I make it in to 2 port system, valves are by star hydraulic can't find any info on them on the net any help would be greatly appreciated
    Paul.W
    help hook up for 3 ph forklift-hydro-done-jpg
  2. #2
    New Member
    Join Date
    Apr 2013
    Posts
    7
    Southwestern New York
    Kubota L4400 , Belarus 800M
    Default Re: help hook up for 3 ph forklift
    Does the fork lift have side to side hydraulic movement?
  3. #3
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    The fork lift should operate fine without attaching the quick disconnect to anything. The only thing I can think of for the quick disconnect to attach is a hose to sump for return oil but when spool is moved to let down forklift hyd oil would also be going to sump under hyd pump pressure.
  4. #4
    Member
    Join Date
    Aug 2009
    Posts
    44
    No side movment
  5. #5
    Member
    Join Date
    Aug 2009
    Posts
    44
    Someone also told me that this should work without hooking it up I was afraid I will damage the pump if there is no return and the pressure will keep building up but there is a pressure relief valve on the spool so it should be OK I will try that and let you know Thank You
    Paul.W
  6. #6
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,066
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Quote Originally Posted by Tx Jim View Post
    That is how I see it as working. A way to drop the forks quicker.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  7. #7
    Member
    Join Date
    Aug 2009
    Posts
    44
    So I hooked up everything top link works perfect the carriage for the fork lift goes up but it stays there moving the spool handle backwards makes the hose jump a bit but nothing happens
    Paul
  8. #8
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,623
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by wpala View Post
    Paul
    Which hose jumps?
    Need pictures. Show valve and hoses. What does the top of the lift cylinder have on it?
  9. #9
    Join Date
    Feb 2013
    Posts
    7,623
    Meridian, OK
    I looked at your first picture, I think the quick disconnect has to go to the return line to the reservoir. You can put a tee with a matching QD any where in the return line.
    How and where are the in/out hoses connected?
  10. #10
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    Paul
    Did you attach the breakaway coupler to dump into sump on the hose that was on the valve??
Similar Threads
  1. need help with hook ups on john deere 750 to hook up FEL
    By krisbodean85 in forum John Deere Owning/Operating
    Last Post: 04-18-2013, 08:38 AM
  2. 3 Pt Forklift
    By ch47dpilot in forum Build-It Yourself
    Last Post: 04-29-2011, 09:04 PM
  3. Replies: 0
    Last Post: 05-05-2008, 03:23 PM
  4. Forklift
    By BSims66173 in forum Build-It Yourself
    Last Post: 11-22-2002, 11:35 PM
  5. Forklift
    Last Post: 11-19-2002, 10:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
