Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    1
    princeton,texas
    1989 ford 1720
    Default 3-point is jumping up and down
    my ford tractor 3-point just keeps hoping up and down by itself. what can be wrong with? i just filled with oil and it keeps doing that. i can't find any oil leaks on the ground or anything.
  2. #2
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default
    Is it maybe leaking down and then being pushed back up by the hydraulics? If you turn off the tractor, does the three point stay up?
  3. #3
    Join Date
    Jun 2009
    Posts
    1,565
    Douglas County, Oregon
    09' Kubota b3200HST
    Default Re: 3-point is jumping up and down
    How low was it? You may have air in the system. Hopefully cycling the three point several times should correct the problem.
  4. #4
    Veteran Member Fawken's Avatar
    Join Date
    Apr 2013
    Posts
    1,000
    Royse City, Texas
    Ford 1100
    Bad parachute seal in the lift. Easy to fix. Get the new seal at NH-Ford and be sure to hone the cylinder while you have it open.
  5. #5
    New Member
    Join Date
    Apr 2013
    Posts
    2
    Texas
    Long
    Long 2460, about 68 model, strong diesel engine ... rear hydraulics will not go up or down, any movement VERY slow and jumpy.. front bucket worked slow, recent Hy. oil and filter change.. found external hydraulic pump, removed and cleaned, put in all new oil again.. front bucket working fine now but no improvement to rear.. Is there a internal pump ?, screen? or ?.. and if so.. location? how to get to it replace or clean it too ?.. have old owners manual but nothing saying where another hydraulic pump or filter might be located.. Appreciate any help.. Thanks
  6. #6
    Join Date
    Apr 2013
    Posts
    1,000
    Royse City, Texas
    Ford 1100
    3-point is jumping up and down-0417121752-00-jpg3-point is jumping up and down-0417121753-00-jpgNo internal pump I know of. Here's the deal: Its probably a bad seal on the lift cylinder, but could also be the pressure relief valve or the lever sensor valves. Was your old fluid black?
  7. #7
    New Member
    Join Date
    Apr 2013
    Posts
    2
    Texas
    Long
    no old oil was ''greyish'' but is like that every time we check it or change it.. tractor is barn kept so not out in the weather..
    Will check cylinder lift as have not done that.. Where would we find pressure relief valve or the other valve.. have good mechanic but with little "Long knowledge''... Thanks !!
  8. #8
    Join Date
    Apr 2013
    Posts
    1,000
    Royse City, Texas
    Ford 1100
    The pictures show a Ford, but I imagine a Long of that vintage would apply the KISS logic and locate it right near where the position control lever is and where the high line enters the contol valve. On Fords its on the right-hand side of the cylinder. Usually, 6-10 bolts will get you a look-see at the cylinder and seal.
Similar Threads
  1. Jumping Ship
    By megaboz in forum Kubota Owning/Operating
    Last Post: 05-25-2011, 05:02 AM
  2. Finally jumping in ...
    By MyThreeSonsMowing in forum New Member Introductions
    Last Post: 02-09-2011, 09:00 PM
  3. Jumping up again!( Perhaps)
    By lawn_king in forum Kubota Buying/Pricing
    Last Post: 01-17-2008, 04:16 PM
  4. Jumping in with both feet
    By bravo36 in forum Kubota Buying/Pricing
    Last Post: 08-09-2007, 07:19 PM
  5. No jumping??...No kidding...
    By BTDT in forum Photos
    Last Post: 01-18-2007, 07:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
