Results 1 to 6 of 6
  1. #1
    Platinum Member dntfxr's Avatar
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default Adding a loader, where/how can I tap into hydraulics?
    The tractor is my 76 JD2040 which is open center. I'm going to put a used loader on it and I'd like to mount the valve on the loader so I'll only have two lines going to the tractor. If possible I'd like to put quick connects so I can remove the loader if I need to. Anyone familiar with how/where to connect in? Thanks for any help
    "Even a tuff ol thistle makes a good boot cleaner.."
    LS XR4155C
    Ford 3610
    Ferris is700 61" Vanguard BB
  2. #2
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default
    Alright so I've been researching this and I've discovered that deere offered a hydraulic filter cover with a return port built in. Mine doesn't have this port but I've located one online. Would this be the best way to return the fluid? I'll check in my repair manual and see if there are any ports on the case somewhere for the pressure side. Hopefully some of the experienced deere members will see this thread and give me a push in the right direction. Any help is appreciated
    LS XR4155C
    Ford 3610
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Adding a loader, where/how can I tap into hydraulics?
    When you install the loader, you will probably have three hoses from the loader.
    INPUT hose
    OUT hose
    PB hose.
    When you remove the loader, you connect the INPUT hose to the PB hose, and that restores the series flow from pump to the rest of the hyd. Plug the RETURN hose to the loader.
    Hydraulics:
    Type: open center (early)
    closed center (late)
    Capacity: 7.9 gal [29.9 L]
    Valves: 1
    Pump flow: 13.5 gpm [51.1 lpm]
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,082
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Quote Originally Posted by dntfxr View Post
    Here's a schematic of the way JD plumbed the loader hyd valve on an open-center system. A ported filter cover isn't needed on an OC system but is required on a CC system. The manifold(parts key #28) is still available from JD.
    W21205 MANIFOLD ADD 283.93 USD
    Attached Thumbnails Attached Thumbnails Adding a loader, where/how can I tap into hydraulics?-wp1704_________un01jan94-gif
  5. #5
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default
    Awesome thanks guys. Just to be clear, in the schematic, which part is the manifold?
    LS XR4155C
    Ford 3610
  6. #6
    Join Date
    Jan 2007
    Posts
    7,082
    Coyote Flats,Tx
    Parts key # 17 in this photo.
    Attached Thumbnails Attached Thumbnails Adding a loader, where/how can I tap into hydraulics?-capture-jpg
Similar Threads
  1. Loader Ford 1600: How to tap into hydraulics to add loader?
    By adamg in forum New Holland Owning/Operating
    Last Post: 08-26-2014, 10:52 PM
  2. 54 FORD NAA Hydraulics tap
    By JayJay99 in forum Hydraulics
    Last Post: 12-06-2012, 09:55 PM
  3. Need help on where to tap into hydraulics
    By mark2610d in forum Hydraulics
    Last Post: 03-16-2009, 06:37 PM
  4. Adding loader hydraulics to my YM1110D
    By gjbirky in forum Yanmar
    Last Post: 02-23-2009, 05:05 PM
  5. need to tap into hydraulics, TL 2100F
    By corelokt308win in forum Iseki
    Last Post: 04-06-2004, 11:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
