Results 1 to 10 of 10
  1. #1
    Member
    Join Date
    Sep 2008
    Posts
    26
    Default Kioti KB2365 Backhoe PTO Pump
    Hope someone can point me in the right direction with a replacement pump cross over. The Kioti BH has the factory PTO Pump kit and I have developed a significant leak from the pump. The only information on the pump is the following:
    JOYANG
    NAME-GEAR PUMP
    SPEC- 31cc-L
    Serial: JD 06041
    I can't locate a rebuild kit for the pump and I would like to just replace it with an alternate brand if some hydraulic guru on here can provide me a reference or an idea of what I need to be looking at. This backhoe is on a Kioti LB1914. Thanks
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Kioti KB2365 Backhoe PTO Pump
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Member
    Join Date
    Sep 2008
    Posts
    26
    JJ, Thanks for the reply. The current pump is more like the one in this link. The one you identified wont fit in the PTO area of my tractor. The one on the tractor has a direct connect adapter from pump shaft to PTO and fastens with two bolts to a removable plate that straddle the sway bar to keep pump from rotating.
    Surplus Center - 1.3 cu in PARKER PZG HYD GEAR PUMP
  4. #4
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Is there a gear box attached to the pump. That pump will provide 9.4 GPM at 1725 rpm.
    Your tractor will provide about 6 GPM.
    Hydraulics:
    Type: open
    Pump flow: 6 gpm [22.7 lpm]
    J.J.
    Git er done.
  5. #5
    Member
    Join Date
    Sep 2008
    Posts
    26
    No gear box attached. It is direct connect to PTO. Below is an image of how the current set up is in the link below:
    http://www.michironandequip.com/page...0201KB23650009
    Attached Thumbnails Attached Thumbnails Kioti KB2365 Backhoe PTO Pump-hydraulic-jpg
  6. #6
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    The pump appears to be directly connected, and therefore it would run at 540 or 1000 rpm if your tractor has a two speed PTO.
    However, the pump you referenced above, would run at 1725 rpm to pump 9.4 GPM at a constant speed..
    http://www.surpluscenter.com/item.as...name=hydraulic
    Is the rpm for your pump and the pump you referenced that different.
    If you directly couple that pump above and run it at 540, you will get about 1/3 of 9.4 GPM.
    J.J.
    Git er done.
  7. #7
    Member
    Join Date
    Sep 2008
    Posts
    26
    I have not been able to locate any additional information on my current pump, GPM or Pressure. My tractor does have a 2 speed pto (540 & 1000). Could someone provide some guidance or insight on a similar small pump that would work. This only operates a small backhoe attachment, but it works very well. I will go through a dealer if I have to, but I am just looking for a cheaper alternative (new dealer pump is over $500.00) that would be easier to get rebuild parts for in the future. I am thinking I need something like 8 gpm/ 2500 psi at 540 rpms that is single stage. All assistance is appreciated.
  8. #8
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,208
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Curious: you say your pump has developed a significant leak.Where is it leaking from? Why do you think it began to leak?
    Is there nothing that could be done to repair the pump by a qualified hydraulics shop or machine shop?
    Just trying to kick around some alternatives to replacement....
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  9. #9
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    The PTO pumps in post #2 sits right on the PTO shaft , and will power your BH.
    They are Prince pumps and you can get parts anytime.
    You can get a cheaper pump, but you will have to gear it up for the pumps operating rpm.
    http://www.surpluscenter.com/sort.as...rch=pto%20pump
    If you are trying to get 10 GPM, at 540 rpm, you need a 4.2 cu in pump.
    To power the 10 GPM pump, you need about 21 HP.
    ---------------------------8 GPM--------3.4 cu in,requires about 16 HP.
    J.J.
    Git er done.
  10. #10
    Member
    Join Date
    Sep 2008
    Posts
    26
    JJ- Thanks for the advice
    coyote machine-the aluminum casing rubbed against the plate (item 14 on above diagram) causing it to leak. Even looked in to having it welded, but no go.
    At this point I am going to follow JJ's advice and go with the prince pump and be done with it. I need to use the BH so this is the best option for now. Thanks
Similar Threads
  1. Koiti KB2365 backhoe
    By Big Bri in forum Attachments
    Last Post: 03-23-2011, 03:22 PM
  2. BigFeet on KB2365 backhoe
    By IslandTractor in forum Kioti Owning/Operating
    Last Post: 03-27-2007, 07:52 PM
  3. Backhoe Connecting KB2365 Backhoe to Kioti LK3054?
    By todson in forum Kioti Owning/Operating
    Last Post: 10-10-2005, 10:50 AM
  4. PTO speed for KB2365 hoe (on my new LB1914!)
    By Maineiac in forum Kioti Buying/Pricing
    Last Post: 05-07-2005, 10:43 PM
  5. Backhoe Backhoe - Tractor Pump or PTO Pump which is better
    By LoganWildman in forum Attachments
    Last Post: 03-15-2004, 11:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
