Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,082
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: John Deere 310 A hydraulics quit!
    Quote Originally Posted by Johnpaul View Post
    Where is the engine disconnect clutch?
    Engine disconnect clutch is located right behind the flywheel. The frt hyd pump has nothing to do with tractor moving/not moving. It is possible one of the gears in the trans pump(charge) broke(2nd photo). Block on RH side is the reverser control valve(3rd photo). Does tractor have a pto?
    Attached Thumbnails Attached Thumbnails John Deere 310 A hydraulics quit!-m20039_________un01jan94-gif   John Deere 310 A hydraulics quit!-tp12720________un01jan94-gif   John Deere 310 A hydraulics quit!-tp41786________un01jan94-gif
  2. #12
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Did you mean that all hyd quit, including the implement pump for the loader and 3pt?
    Maybe you mean the hyd drive train.
    Does your engine still run?
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #13
    New Member
    Join Date
    Apr 2013
    Posts
    8
    Wa
    John Deere 310 A
    Quote Originally Posted by DT86 View Post
    I was thinking he meant the pump/engine disconnect.
    Well, I put new filters on and cleaned the pickup screen, which did not appear very plugged at all.. No change in the issue...no hydraulics or forward/reverse what so ever. Hard to know if the input shaft to the hydraulic pump is actually ok or not. The fact that no forward/reverse is still the question that the pump is even the question. How do I check the low pressure supply from the tranny area?
  4. #14
    New Member
    Join Date
    Apr 2013
    Posts
    8
    Wa
    John Deere 310 A
    To determine a broken gear requires the tractor to be split in 2 and exposed. Not sure that would be in the budget or the under taking. Any other tests of determining whether the low pressure supply is reaching the hydraulic pump?
  5. #15
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    You can put a gauge on the low pressure supply to the big pump. I had to do that on my 2355 once. I don't know what the pressure should be however.
  6. #16
    Join Date
    Jan 2007
    Posts
    7,082
    Coyote Flats,Tx
    Trans pump pressure should be 165 psi. Pressure can be checked on shift valve that's located on RH side in my 3rd photo from previous post.To check condition of drive clutch I suppose one could remove the clutch housing cover,VERY CAREFULLY bump engine over and see if input shaft is moving.
    DOES your tractor happen to have a PTO??
    I have limited experience diagnosing JD industrial tractor failures but a lot of experience on JD agriculture tractors which however have a few differences
    Attached Thumbnails Attached Thumbnails John Deere 310 A hydraulics quit!-tp6529_________un01jan94-gif
  7. #17
    Gold Member
    Join Date
    Nov 2011
    Posts
    289
    Canton, TX
    JD 301A and yanmar YM2500
    Default
    The 301 and 310 are based on the jd 1020 ag tractor and share most of the test procedures and psi ranges.
  8. #18
    New Member
    Join Date
    Apr 2013
    Posts
    8
    Wa
    John Deere 310 A
    No pto , it has a permanent backhoe
  9. #19
    Gold Member
    Join Date
    Nov 2011
    Posts
    289
    Canton, TX
    Default
    I have a 301a and lost all hydraulics when the loader valve failed internally. Might be worth checking the return to make sure it isn't flowing with no controls engaged. The tractor has a closed center main system that can suck all available fluid from the oc charge pump.
  10. #20
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,623
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel
    Quote Originally Posted by medic0648 View Post
    Since FEL use was last action before failure your experience could apply in this case too.
Similar Threads
  1. John deere 310 steering locking up
    By jusalooking in forum Construction Equipment
    Last Post: 08-31-2012, 08:51 PM
  2. John Deere Mod 310
    By say001 in forum John Deere Lawn & Garden
    Last Post: 08-26-2012, 05:59 AM
  3. Backhoe john deere 310 d
    By danny223 in forum John Deere Owning/Operating
    Last Post: 10-14-2011, 09:27 AM
  4. john deere 310 D backhoe
    By Rwelder in forum Construction Equipment
    Last Post: 05-09-2011, 07:52 PM
  5. john deere 310 D backhoe will not dig
    Last Post: 03-06-2011, 08:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
