Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Veteran Member lhfarm's Avatar
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    Default Re: Where to place pressure gauge in simple open center system?
    Quote Originally Posted by Xfaxman View Post
    Are you using oil or hydraulic fluid? Some pumps are designed to use motor oil.
    I'm using hydraulic fluid marked 20W. Instructions called for 10W oil. I may try to change to oil after I test the flow direction.
    Thanks,
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
    '47 Willys Jeep CJ2a w/ PTO
    '49 Willys Jeep CJ3a w/ PTO & 3pt lift
    http://www.farmjeep.com/
  2. #22
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    Over the weekend was able to drain the tank and disconnect the hoses to test the flow direction. It is correct. However, when draining the tank, there was only a couple of quarts of fluid. I had added the 5 quarts per instructions when I started testing. Assuming another quart remained in the hose, pump and ram, I was running a couple of quarts low. There is no way to see, test the fluid level and I hadn't realized that I had lost that much fluid through leaks.
    When I reconnected the hoses and added 4 quarts of fluid, the lift worked. It would raise 3 large adults (~ 600 pounds) standing on the draw bar. The pressure gauge still only read about 400 PSI, so the pump may be worn, but it will certainly lift any plow I'd hang on the back.
    I will accept the idiot of the month award for not checking the fluid level earlier. Thanks for all your time and suggestions.
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
  3. #23
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    You can install the pressure gage in a tee at the IN port of the first valve.
    Pressure developed is determined by the load, or providing some resistance to the flow as in extending a cyl to the end and holding that position.
    The relief will go off at the set pressure if the system is good.
    If you had a leak that bad, you would surely know it.
    Do you have a filler cap that you can remove and look in the tank?
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #24
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,896
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by lhfarm View Post
    I hope you used motor oil this time, like the instructions call for on page 3. The Gerotor pump it uses will not develop full pressure with hydraulic oil. You can use 20W, since you are not farming with it in the winter.
    You need a vented pipe plug on the fill tube, as marked here:
    Where to place pressure gauge in simple open center system?-diagram4-jpg
    Good luck at the shows!
  5. #25
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    Quote Originally Posted by J_J View Post
    I had several leaks so it was possible. The filler pipe extends from the tank and has a 90 degree elbow. So you can't see into the tank or otherwise tell the level of the fluid. I am assuming I can fill up to the level of the filler pipe, but no more.
    I didn't use motor oil, but will give it a try, just to see if it makes a difference. I'll have to design a vented pipe plug. I used a small extension pipe when I cycled the pump several times, but put the solid plug back as shown.
    The shows aren't competitions, just displays. But I do want the lift to be as original as possible.
    Thanks,
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
  6. #26
    Join Date
    Feb 2013
    Posts
    7,896
    Meridian, OK
    Right, I think you should see oil in the elbow
    Thanks,
    You can buy a vented pipe plug if you want to.
    Where to place pressure gauge in simple open center system?-172-square-head-pipe-plug Where to place pressure gauge in simple open center system?-thumb_1797_1797_breather-fitting-1-8-npt
Similar Threads
  1. Replies: 12
    Last Post: 04-28-2013, 02:29 AM
  2. Open Center VS Closed Center
    By RottenGround in forum Hydraulics
    Last Post: 03-23-2013, 12:36 PM
  3. Tandem center vs Open center valves
    By Eric_Phillips in forum Hydraulics
    Last Post: 02-14-2009, 10:14 PM
  4. closed or open center system
    By tlj22 in forum Hydraulics
    Last Post: 12-12-2008, 06:21 AM
  5. I added a pressure gauge to the hyd. system....
    By montejw in forum Parts/Repairs
    Last Post: 03-01-2007, 09:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
