Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    5
    Pitman, NJ
    John Deere 1650
    Unhappy JD 1650 Steering Hydraulics Working Against Me
    Hi, sorry if this is in the wrong section, I figured other makes of tractors and machines have similar hydraulic steering setups. I'm working on a John Deere 1650 tractor. When first started, the power steering works fine, but after about 10 seconds or so it is very difficult to turn to the wheel. Sometimes there's a shudder as your turning the wheel (loose, tight, loose, tight, etc). I lifted the front axle off the ground with a fork lift, and checked the bearings and tie rod ends. With the steering gear disconnected, the the front wheels turn left and right very easily by hand, so no issues up front. I reconnected the steering gear and turned the wheels with the tractor off. There's no binding or resistance and the wheels can be turned from stop to stop with one finger. I then started the engine, and at idle the steering becomes difficult, but there's no shudder like there is with weight on the axle. As I increase the engine RPMs the steering becomes progressively more difficult to operate. It takes slightly more effort to turn the wheel right than it does to turn it left.
    Since the steering gear works perfectly with the engine off, I'm almost sure there's a hydraulic problem somewhere. Perhaps a blockage in a return line or a malfunctioning valve in the gearbox itself? I also noticed hydraulic oil being pushed out from behind both of the rockshaft arms, which seems to have started around the same time. This happens all the time, without even using the hitch.
    I'm trying to locate a pressure test / flow meter set to borrow, but for the time being i'm just guessing. I don't want to just start throwing parts at it. Any advice is greatly appreciated. Thanks.
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,240
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: JD 1650 Steering Hydraulics Working Against Me
    I think you need to acquire a JD tech manual of which I have not. I'll guess that it's possible that parts keys #35 & 36 have failed.
    Attached Thumbnails Attached Thumbnails JD 1650 Steering Hydraulics Working Against Me-m7291__________un01jan94-gif
  3. #3
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,841
    South West MI
    John Deere 2030, John Deere 6415
    I'd start with the basics first.
    Check hydraulic oil level/condition
    Change the hydraulic filter Key 12
    Clean or replace the suction filter/screen key 10
    Attached Thumbnails Attached Thumbnails JD 1650 Steering Hydraulics Working Against Me-1650filter2-gif   JD 1650 Steering Hydraulics Working Against Me-1650filter-gif
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  4. #4
    New Member
    Join Date
    May 2013
    Posts
    5
    Pitman, NJ
    John Deere 1650
    The hydraulic oil level was fine. I drained the oil and removed the filter screen in the rear. The oil was very dark and full of very fine dirt particles. there's quite a bit of small silver metallic pieces stuck to the screen. There's a few gold/brass ones. You can see the color of the old oil and filter screen in the picture below. I'm trying to locate a tech manual now.
    JD 1650 Steering Hydraulics Working Against Me-image-jpg
  5. #5
    Join Date
    Aug 2010
    Posts
    3,841
    South West MI
    Did you replace the spin on hydraulic filter? It might be plugged.
  6. #6
    New Member
    Join Date
    May 2013
    Posts
    5
    Pitman, NJ
    John Deere 1650
    I'm going to try and locate one on Monday in Fram or Wix. My local JD dealer didn't have one on the shelf. They are undergoing a change in ownership.
  7. #7
    New Member
    Join Date
    May 2013
    Posts
    5
    Pitman, NJ
    John Deere 1650
    So, I cut apart the old filter and inspected the fiberglass element. It was 100% restricted with fine particulate matter. I got a new JD filter from the dealer (finally) and refilled with fresh Hy-Gard. I was all ready to start taking the steering gear out. I started it up and let the new oil circulate, and the steering worked great! Who would of thought? No more leakage around the rockshaft arms either. I'm going to change the filter again after running it a little. I'm sure there's more dirt in there that didn't come out when I drained it.
  8. #8
    Join Date
    Aug 2010
    Posts
    3,841
    South West MI
    Thanks for the update, sure to help others with same problem
  9. #9
    New Member
    Join Date
    Feb 2013
    Posts
    24
    floyd,va.
    4040 john deere
    If this tractor has wet brakes, the stuff you found in the filter may be brake lining. I would check the hyd fluid again in a couple days.
  10. #10
    New Member
    Join Date
    May 2013
    Posts
    5
    Pitman, NJ
    John Deere 1650
    Internet says it has "differential hydraulic wet disc". Is this a byproduct of normal wear, or should I be concerned? I'm not sure when the last time the hydraulic oil was changed, if ever. Haha.
Similar Threads
  1. Hydraulics not working
    By obb in forum Hydraulics
    Last Post: 02-10-2013, 08:08 PM
  2. Hydraulics not working
    By CATMAN3208 in forum Hydraulics
    Last Post: 11-24-2012, 10:36 AM
  3. jd 850 HYDRAULICS NOT WORKING
    By bgreene in forum Hydraulics
    Last Post: 03-23-2012, 09:54 PM
  4. Jinma hydraulics and power steering stopped working
    By ryanrancher in forum Hydraulics
    Last Post: 09-22-2011, 12:41 PM
  5. Mitsubishi 1650 3PH not working
    By Jerry A in forum Hydraulics
    Last Post: 09-06-2008, 04:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
